oem vs jdm sr20
Old 11-15-2002 | 06:48 PM
konseiEva's Avatar
oem vs jdm sr20
what's the difference between the jdm and oem sr20?
Old 11-15-2002 | 07:00 PM
Justin.b's Avatar
Which SR20?
There's not too much difference between the JDM and US SR20DE installed in the front wheel drive Sentra and G20.
But, there was never a RWD SR20 motor sold in any car in the US. There was also never an SR20DET (turbo) motor sold in any configuration (FWD/RWD/AWD) in the US.
So every SR20DET in the US was imported from someplace where the motor was installed as original equipment - usually Japan. The same goes for any RWD configured SR20DE.
-Justin
www.saltgod.org
Old 11-15-2002 | 11:18 PM
rudeboy's Avatar
and the olny diff between the n/a and det is CR and ecu
on FWD ser's
or 00 se's
Old 11-16-2002 | 04:17 AM
boro240's Avatar
i think the only nissan I4 'T' motor the US ever got was the CA18ET in the 200SX
Old 11-17-2002 | 07:17 AM
Silviaspeed's Avatar
It was turbo boro? Other then the 300Z I didn't think anything else Nissan brought over here was turbo.
Also some other differences between the USDM and JDM SR's would have to do with the placement of some of the components. I'm not sure which ones they are, i.e. alternator, AC compressor, etc. But I'm sure one or two components are located on the opposite side of the block. This in part to the firewall being in the way on a tranverse mounted SR.
Old 11-17-2002 | 08:00 AM
drifties151's Avatar
so if i bought an Infinity G20 (what years??)... I could drop a FWD SR20det into it?? is that what the Primera's had in them over in japan? i think i found my new project car if this is true, i would love to drop an sr20 into one of the newer G20's, like 99-00 bodystyle.
Old 11-17-2002 | 09:12 AM
The G20 comes with the SR. Just add turbo. Voila!
Old 11-17-2002 | 09:39 AM
so all that good stuff off of toda racing would work on a G20? just adding a turbo wouldn't be the same though... would it? the compression ratio would be different and so on... if i could get a red top bluebird engine into a g20 it would be all set to boost it up. check out this stuff, tell me if u think it would work in a US spec sr20de motor found in 99-00 G20.... http://www.todaracing.com/products/n...camshafts.html
Old 11-17-2002 | 04:41 PM
I'm not about those cams drift. Theoretically they should work, but I don't know for sure. Basically, the SR came in the:
Sentra
G20
200SX (95-whenever)
Yes a Bluebird GT-i motor will fit right into a G20, as it will fit into a Sentra or 200SX. I wish some of the Sentra owners would hop onto this topic and clarify some things. I've been to a few of there meets and they roll deep with tons of different setups. From Bluebirds to custom turbo apps. on their Sentra's and 200SX's. If you've seen a turboed Honda or Eclipse, then you know what a Sentra, 200SX, G20 engine bay would look like. Just get a turbo mani with a nice turbo, run some IC plumbing and the works. Your all set.
Old 11-17-2002 | 08:37 PM
Mike 240SX's Avatar
We also got the E15iT in the 1st generation Pulsar NX (83-85). Unfortunately, the only trans choice was a 3spd auto.
Old 11-17-2002 | 09:57 PM
I'm with Stupid's Avatar
Sentra
G20
200SX (95-whenever)
Basically on the sentra and 200sx it only came in the SE(-R) trim. Oh and don't forget my favorite the NX2000.
Old 11-18-2002 | 12:44 AM
boro240's Avatar
was it carburated or something? whats the i?
Old 11-18-2002 | 12:45 AM
boro240's Avatar
yeah the S12 200SX came with the CA18ET as one of the engine options.
Old 11-18-2002 | 12:01 PM
spitz7985's Avatar
NX2000.
fugly
Old 11-18-2002 | 12:16 PM
Originally posted by spitz7985
fugly
I don't think so. The front is wierd though, but the back is nice.
