OBD-II/MIL codes 94.5-98
1996 OBD-2/MIL codes
the following is a compete codes list for the 1996 240sx ka24de. I'm sure these apply to 94.5-98 (possibly all 240's), but I havent checked on that yet. There are some turbo codes in this list, so these may be the JDM codes also. Again I will check these things out and get back to you. Those of you w/ sr20det's let me know if the turbo codes at the bottom match up w/ any list you have. I'll get into how to pull these codes in the privacy of you own home later for those that dont already know.
OBD-II/MIL-Item affected
P0000/0505-No fault detected-System ok
P0100/0102-Mass air flow sensor unit
P0105/0803-Absolute pressure sensor
P0110/0401-Intake air temperture sensor circuit
P0115/0103-Engine coolant temp sensor circuit
P0120/0403-Throttle position sensor circuit
P0125/0908-Engine coolant temp sensor
P0130/0307-Closed loop control-right/front ho2s
P0135/0901-right/front ho2s-heater fault
P0136/0707-closed loop control-right/rear ho2s
P0141/0902-right/rear ho2s-heater fault
P0150/0308-closed loop control-left/front ho2s
P0150/0303-closed loop control-left/front ho2s
P0155/1001-left/front ho2s-heater fault
P0156/0708-closed loop control-left/rear ho2s
P0161/1002-left/rear ho2s-heater fault
P0170/0706-fuel injection system-control fault
P0170/0115-fuel system lean-right bank on v6
P0172/0114-fuel system rich-right bank on v6
P0174/0210-fuel system lean- left bank
P0175/0209-fuel system rich- left bank
P0180/0402-fuel temperature sensor circuit
P0300/0701-multiple cylinder misfire
P0301/0608-no. 1 cyl. misfire
P0302/0607-no. 2 cyl. misfire
P0303/0606-no. 3 cyl. misfire
P0304/0605-no. 4 cyl. misfire
P0305/0604-no. 1 cyl. misfire
P0306/0603-no. 2 cyl. misfire
P0325/0304- knock sensor circuit
P0340/0101-camshaft position sensor
P0400/0302-EGR system function
P0420 /0702-catalyst function-right bank on v6
P0430/0703-catalyst fucntion-left bank
P0440/0705-EVAP emission system-small leak
P0443/0807-pruge control solenoid & valve
P0446/0903-vent control valve
P0500/0104-vehicle speed sensor
P0505/0205-idle air & auxilary air control valve
P0510/0203-closed throttle position switch
P0600/ N/A-auto trans communication line
P0605/0301-engine control module (..feel sorry for you! )
P0705/1003-(1) park/neutral position switch
P0710/1208-(1) transmission fluid temp sensor
P0720/1102-(1) vehicle speed sensor
P0725/1207-(1) engine speed sensor
P0731/1103-(1) auto trans 1st gear signal
P0732/1104-(1) auto trans 2nd gear signal
P0733/1105-(1) auto trans 3rd gear signal
P0734/1106-(1) TCC & 4th gear signal
P0740/1204-(1) TCC solenoid vavle
P0745/1205-(1) line pressure solenoid
P0750/1108-(1) shift solenoid valve "a"
P0755/1201-(1) shift solenoid valve "b"
P1105/1302-MAP/barometric switch solenoid
P1150/1306-wastegate control solenoid-right
P1155/1307-wastegate control solenoid-left
P1160/0206-turbocharger boost sensor
P1220/1305-fuel pump control module
P1320/0201-primary ignition signal
P1336/0905-crankshaft position sensor
P1400/1005-EGR control solenoid valve
P1401/0305-EGR teperature sesor
P1441/0801-vacuum control/bypass valve
P1443/0113-canister vacuum check switch
P1445/1008-EVAP purge volume control valve
P1447/0111-EVAP purge control monitor
P1605/0804-auto trans communication line
P1705/1206-(1) throttle position sensor a/t
P1760/1203-(1) overunning clutch solenoid valve
P1900/1308-cooling fan/overheat
OBD-II/MIL
The first code is the OBD display code and the second (MIL) is a flash code. EX 0102= 1 slow flash and 2 quick flashes. Or EX2. 1203= 12 slow flashes and 3 quick flashes. what flashes is the engine check light. Not all 240's even have a OBD plugin so the MIL is the only way to pull the code.
OBD-II/MIL
Driftin RPS13
06-01-2004 10:30 PM
