need some electrical problem
my meters fuse keep on blowning... so far i replace it 3 times within yesterday and today. yesterday the first time the meters fuse blown.the rpm, speed, and temperature gauges doesn't work.then today the second time the meters and radio fuse was blown.so my mp3 deck doesn't work. i also replace both fuses. then i was driving to get some gas and the meter fuse blown on me again, this time the slide seat belt didn't work along with the rpm, speed, and temperature gauge..i'm pretty sure i don't have any wires touching each other.i don't know what can cause this..anybody have a clue about this..???
the reason you have a certain amp rating on your fuses is to protect your wiring and electronics on the other side. you must have too high of an amp draw and its causing your fuse to blow. either that or your wires are getting pinched/worn somewhere and touching ground or each other.
I dont really agree with throwing a higher amp fuse in there cause it could cause other problems like melted wires or your electronics could get damaged. Something in your circuit is prob going bad and causing too big of a draw. Did you tap into your power around your radio to add something?
haven't touch the radio...before my meter fuse start to blown, i was removing my tar so i got the seat removed. i notice there was a ground wire under the seat connected to the car. it was tight not lose or anything..then yesterday i took the car out for a drive and was flooring pretty hard, then as i slow down the rpm, spd, temp gauges just stop working.i got home and check the meter fuse and it was out, so i replace it with another 10.that was when the fuse start blowing.then today i have replace the radio and meter fuse with 10.then i drove to get some gas and the meter fuse blow, the slide belt didn't work and gauge didn't work.when i got home i replace it with a 15..
i do have some ground wires made out of 4g connected to my battery to motor to engine bay wall...can that cause the blowing fuse? but i been having that for almost a month now and this never happen...a wire must got loosen when i was flooring my car the other day..
how do i look for short?..sorry i know nothing when it come to electrical problem..i was just wondering if my meter fuse keep on blowing, is it that any sign that my gauge is going bad? today i drove it to the store down the street and the meter fuse blow so the fan and gauges stop working. if the fuse keep on blowing, is it ok to drive the car or can that cause more damage?
i did some research.....so do you take the dash off and follow the meter wire until you see a short( touching ground, broken wire, ects)...is that how you do it? i'm about to move to sac in two weeks and i need my 240 as a DD for school so any helpful tip will be appreciated..
bagnasco
05-12-2008 02:15 PM
scrapp
09-03-2004 09:35 AM
