my high beam is out?
Old 09-09-2005, 04:33 PM
shotty53's Avatar
Im curiois if any1 would know whats wrong with my highbeams
my left highbeam went out. I checked the bulb and it was good. What i did is do a current test to see if the wire had power running through it to the lights, but nothing. Is it the plug harness or maybe a loose calbe or a fuse?
Right now i have a wire running from the highbeam on the rightside powering both highbeams...
edit** my fuses are fine
shotty53 is offline
Old 09-09-2005, 05:21 PM
steve 14's Avatar
step one buy new bulb or swap from other side
step two come back and tell us whats up
steve 14 is offline
Old 09-09-2005, 06:11 PM
shotty53's Avatar
still nothing. i swappe them and it is still out
shotty53 is offline
Old 09-09-2005, 06:18 PM
steve 14's Avatar
s13 of s14
if i rember right in the s14 theres a sub harness that goes the the high to low light check that out
steve 14 is offline
Old 09-09-2005, 06:20 PM
shotty53's Avatar
alright. ill try that out when theres some sun out
shotty53 is offline
Old 09-11-2005, 11:43 AM
acfalconhawk's Avatar
My right high goes out and occasionally if i flash them, both are out. it has had this problem for years.
acfalconhawk is offline
Old 09-12-2005, 11:50 AM
Madman Stephan's Avatar
Funny thing....
... I'm in the same boat! I noticed in early spring that my RHS high beam quit. The low beam was still good, so of course, I replaced the bulb and still no high beams! I kinda forgot about since I rarely use them, but now, days are getting shorter....
I haven't done any trouble shooting yet, but I wouldn't be surprised if we had the exact same problem.
Thanks for reminding me!
Madman Stephan is offline
Old 09-12-2005, 12:42 PM
2fast4y0u's Avatar
i had both of mine go out at the same time. but mine was easy, replaced bulbs
check the fuse box - you said the fuse was fine but check to see if there is power going to the fuse. remove the fuse turn on the lights and put a volt meter in the fuse hole.
2fast4y0u is offline
Old 09-12-2005, 04:41 PM
my dad said it was a problem with the "pigtails" for the lights. dunno what that means.
Old 09-12-2005, 05:23 PM
I'm with Stupid's Avatar
I had this problem. It's common. You need a new switch.
I'm with Stupid is offline
Old 09-13-2005, 05:08 AM
Switch? What switch?....
Old 09-13-2005, 09:31 AM
reefer1114's Avatar
Originally posted by steve 14
s13 of s14
s13 dont have high beams...
reefer1114 is offline
Old 09-13-2005, 02:36 PM
steve 14's Avatar
what?
steve 14 is offline
Old 09-13-2005, 03:38 PM
shotty53's Avatar
yeah they do
shotty53 is offline
Old 09-13-2005, 04:56 PM
The only switch in the entire circuit. You know, the one mounted to the steering column, you physically grab with your hand and twist and push to operate?
Quick Reply: my high beam is out?
