Momo Hub adapter need help!!!!!!!!
Old 01-16-2005 | 02:04 PM
cd1921's Avatar
Hey all, does anyone know if a regular momo or sparco adapter will fit a 91 s13 with super hicas, i seen some that say it wont fit them? Or if there is a specially hub made for a HICAS car?
Any help, pics or links are welcome..
Thanks all
Old 01-16-2005 | 02:22 PM
The hub itself will not work. On HICAS equipped models there is a steering position sensor. With the sensor in place it will interfere with the hub. You would have to remove the steering position sensor and then get a HICAS eliminator, but you would lose the HICAS
Old 01-16-2005 | 02:48 PM
cd1921's Avatar
so the hubs will work, but i ll loose the HIcas, i can also pull the fuse to turn it off right... so any hub for a s13 will fit then. thanks man..
Old 01-16-2005 | 03:02 PM
it will work, but you will have to remove the sensor, you cant work around it. Once you remove the sensor you will need a HICAS eliminator
Old 01-16-2005 | 03:14 PM
cd1921's Avatar
Ohh ic, so if u remove the sensor, the lines have to be plugged.. no way around it.. Even if i pull the fuse off?? I would of never gotten a hicas s13 lol lol
thanks for the help again..
Old 01-16-2005 | 03:17 PM
no problem
Old 01-17-2005 | 11:31 AM
it's mechanical, a fuse will just cut electrical current.
SonyPete
02-24-2005 11:17 PM
chissan
01-18-2005 06:26 PM
StanBo
09-28-2004 10:28 PM
Dorifto180
12-22-2003 08:34 PM
NightSlide Josh
05-23-2003 01:24 PM
