Losing Coolant!!!!
Losing Coolant!!!!
When i Checked my 1995 240sx SE, i saw that my temp guage was going up high, so i turned off the car and saw that there was no coolant. Ive been having to refill my coolant every once in a while. Whats going on here? Can anyone help me? Does it have anything to do with the heater not working? Please help.
Here are some 1995 problems:
Trouble Spots
Air conditioner: Poor air-conditioner performance due to compressor-joint seals that tend to leak. (1995-96)
Brakes: Nissan issued a voluntary recall to replace a defective diode that will not turn on the low-brake-fluid-warning light. (1995)
Dashboard lights: The check-engine light may come on and set an erroneous trouble code for the crankshaft position sensor if certain wires in the computerized engine-control circuits are not kept separated from one another. (1995)
*Engine temperature: The engine tends to overheat if any air trapped in the cooling system is not properly bled. (1995)
Hope this helps
Heres the rest of the site: http://auto.consumerguide.com/auto/u...ex.cfm/id/2219
Trouble Spots
Hope this helps
hey whatta know...mine to exept with mine will only stay about 3/4 the way full...when i fill it up and just runs right onto the ground and my head gasket is bad to so some of it (when over 3/4 full) burns out of my exhaust. but it hasnt overheated yet, oh and my heat doesnt work either and i live in michigan....yahh...its snowing!!!!
cjm93240sx
05-19-2003 08:29 PM
