Lighting question for electrical gurus.
I've got this headlight issue with my S13 that I can't seem to resolve. My passenger headlight is out about 95% of the time, but sometimes comes on after the headlights have been on for more than 30 mins (much like the HUD issue). The high beam comes on without any issues, its just the low beam. I bought a new bulb and came up with the same result.
Here are some of the variables:
The car used to have driving lights that the previous owner installed (rather poorly) and I removed them.
Headlight fuses are intact.
I traced the wires coming from the headlight back as far as I could to the main harness and didn't find any cut or damaged wires.
Sometimes even if the light comes on, it goes back off while driving.
It seems as though this is a wiring issue rather than the headlight switch itself, as the driver side headlight still works. I am planning to remove the bumper and see if there is something I'm missing...but any advice would be greatly appreciated.
Originally posted by jbask
I would start by checking all the grounds, Then make sure the harness that plugs into the head light is clean and not corroded (?) Hope this helps
Josh.B
Josh.B
Thanks .
Josh.B
Josh.B
If you can't trace it down, I'd consider tapping into your drivers side headlamp. Do this only if there is one fuse for both headlights.
Edited for a typo.
Originally posted by TWong1200
Don't think it's a ground since your high beam works and the share the same ground wire. There are three wires at your headlight, correct? One is for high, one for low, and one for ground which is used to complete both circuits. If one of the circuits works fine everytime (high beam), then it's obvious that the ground is bad. I bank on it being your low beam positive signal.
Tapping into the driver's side light probably wouldn't work out since they each have their own fuses.
Originally posted by l2aine
I'd guess grounds too... then again, If you want to save headaches you could do a simple rewire with a pair of relays and your lights will also shine brighter... post up if you're interested
Sounds interesting, can you post or PM me details?
dont double post..... thats what the edit button is for....
anyway..... are you 100% sure that there are no spots where the wire has been damaged and is touching metal?....... i had this same problem with my maxima and i ended up having to rewire the headlights...
edit: well now that i think about my wording, i didnt " have to " rewire the headlights, but it seemed easier at the time
SoupBA
08-27-2004 01:25 AM
