leaking trunk
Old 12-28-2004 | 11:33 PM
illipse's Avatar
leaking trunk
so my trunk leaks. my question is, is it most likely just a bad seal somewhere? i havent had a chance to inspect it really cus its still raining, but anyone had to deal with the problem before?
would it cost a lot to get a new seal put in?
its a 95 240sx if that matters.
thanks
Old 12-29-2004 | 01:08 PM
tl240's Avatar
it will cost you close to nothing to replace the seal on the trunk and it is easy to do
Old 12-30-2004 | 01:35 AM
you could try adjusting the trunk latch a little lower so that the trunk will close tighter, but if that doesn't work then just replace the trunk seal - simple job
battosaii930
01-16-2007 10:12 PM
s240r
03-17-2004 11:57 PM
mafaqinballs
11-25-2003 07:11 AM
Jonas
08-03-2003 11:19 PM
Rynxprs
10-16-2002 08:21 AM
