ka24e block
ka24e block
so i have to bore my cylinders and so on cuz my piston rings are shot welll i desided to get a block from another ka24e and just get a gasket set and drop my head on it !!!that should work right???well second part is i am planning to get a bnlock from a nissan truck its much cheaper and is exactly the same am i right???is there any other blocks i could drop my head on too!???
hmm
how come stanza wan't work just out of curiosity??? isn't ka24e block the same for all ka24e ??? will the one out of the truck work thow?and also what is requerd to put dohc head on ka24e block if thats possible...
the transmissions (240's) are interchangable from ka24e to ka24de. i dropped a ka..de into my 89 and the tranny matched up fine.
i'm not completely positive if the stanza engine will work.. its the same one but mounted differently (front wheel vs real wheel drive) so might not be a direct drop. could run into mounting and matching probs.
a dohc head will not fit on a sohc
lots of parts are interchangable between the two engines (e and de) but not things like a wiring harnesses, ecu, maf, ps pumps due to mounting. not sure about the oil pan though.
Heely
03-08-2004 05:06 AM
