ka24de trans fit a ka24e?
Old 03-19-2010 | 05:50 AM
B2A4IONsx's Avatar
i am in need of a tran fairly bad, i found a guy with a ka24de with thrown rod comes with 5 speed tranny clutch pressure plate shifter and ecu and non cut harness and drive shaft and mount for $200
one of two things,
A will the tranny fit up to the sohc?
B will they head match up to the SOHC block?
Old 03-19-2010 | 05:09 PM
Yes they are all the same.... the only difference is the Crank angle sensor is mounted in the S14 bell-housings.... just remove it.. it doesn't affect anything
Old 03-20-2010 | 08:39 AM
renato's Avatar
will the 89 ka24e manual tranny fit the ka24de 98?
Old 03-20-2010 | 09:20 AM
it will fit.. however.. there is no location for the crank angle sensor on OBD I bell-housings..... so you will have to with precision drill an exact hole.. and or swap the bell housing.... not worth the hassle.
MrC
01-15-2006 11:12 AM
juls213
02-28-2005 02:46 AM
juls213
02-05-2005 09:20 PM
TattosByJosh
07-15-2004 05:02 PM
Misfitflesh
11-25-2003 01:45 PM
