jack points underneath??
If the jack points on the underbody of the car is messed up will that effect the rigidness of the chassis or frame is it?? i'm not reallly sure about this stuff (terminology) and how it works with the whole car. the car looks as if one side was jacked wrong..
so the under part look a little like this. Driverside
(front) [____________]-._./~~\__.-.__/ (rear)
other side is okay. I got it checked.. guy said it wasn't a problem but that it couldn't be fixed? jsut want to get othe rpeoples opinions
thanks for the replies.. i appreciate it. so i should just find other jack points for stands.. well for the fronts im okay the supports aren't like bent as u can see...yeah i just wanted to know if was a problem.. should i try and get it fix tho if i wanted to jack it from there tho? or maybe not..i prolly shouldnt' do it in that same place..especially that side.eh?
drnovascotia: here are some pictures
