ignition dilemma
Old 12-02-2002 | 07:42 PM
nismo24t's Avatar
Exclamation ignition dilemma
okay, her's the situation...i installed NOLOGY spark plug wires. I wanted to re-install the JACOBS ULTRA COIL, SECONDARY TRIGGER, AND MILEAGE MASTER. Will there be any type of conflict here?
I say this will just amplify the spark. My brother said its not compatible. Any thoughts?
One more thing...is there such thing as a converter for the terminals to make them female to male and vice versa? You know, like the coil to distributor wire, i want to make the female end into a male end. Is there such a thing?
Old 12-02-2002 | 07:48 PM
rudeboy's Avatar
i don't see why the NOLOGY wires wouldnt work with the Jacobs pak....
unless the problem is in the connections
Old 12-03-2002 | 09:38 PM
nismo24t's Avatar
see...dats wut I said..it'll just amplify the spark....jacob's amplifier is the same thing as the NOLOGY amplifier...they both produce more spark!
So...dose anyone know what that thing is called: an adapter or converter that u plug in to make a female connector into a male and vice versa????
I was gonna use this ^ for the second trigger connector to the factory secondary trigger and the ULtracoil to the distributor...but the connectors or terminals are the same...hellp!
Old 12-03-2002 | 09:42 PM
9sorbust's Avatar
Scream this at it
this is the song that doesnt end
it goes on and on my friend
some people started singin it not knowin what is was
and they will be playing with gorrila ***** all night
but when a gorrila pees on you
you scream
ahh stupid ape
if this dosnt work result to the duck tape or fortune cookie
Old 12-03-2002 | 10:05 PM
spitz7985's Avatar
^^^^^^ so was that duck tape or duct tape?
Old 12-03-2002 | 10:09 PM
rudeboy's Avatar
why do i have the feeling that this guy 9sorbust
hangs out with strawberry kid????
Old 12-03-2002 | 10:12 PM
nismo24t's Avatar
Come on guys help!!
Is there such thing as a converter for the terminals to make them female to male and vice versa? You know, like the coil to distributor wire, i want to make the female end into a male end. Is there such a thing? Whta's it called?
Old 12-03-2002 | 10:14 PM
rudeboy's Avatar
although i'm not sure if that connector is out there, why are you lookin to do with these?
Old 12-04-2002 | 09:42 PM
nismo24t's Avatar
well....
i have a JACOB's secondary trigger and I am trying to conect it to the factory secondary trigger....but hey are both females.
I also have a JACOB's ultra coil and I am trying to connect this to the distributor....but they are both female!
I need a connector to make a female male and vice versa!! What are they called?
Old 12-04-2002 | 10:29 PM
rudeboy's Avatar
OK, stupid question:
did ya check the auto parts store?
Old 12-05-2002 | 06:51 AM
nismo24t's Avatar
ya...checkers...autozone....i told them the same scenario....maybe they didn't understand me? There has to be something!!!
Old 12-05-2002 | 10:07 AM
2-FORTY_TERROR's Avatar
ok ok......
first i can asure you 9s doesnt hang out with strawberry......hes a real good friend of mine....and i know he doesnt....but off the point.....checkers....and autozone,...even o'reilys probally just stared at you and then call a co-woker over were you had to repeat your self....so i wouldnt bother with them....i think you best bet is it custom fabricate
p.s.....9s is a little wack though
snake
Old 12-05-2002 | 06:34 PM
nismo24t's Avatar
eeheehehe...dats what they exactly did at Checker's...****** f'er made me explain it twice...and he goes "nothing I would carry." I was like okay..***!
yarou
05-23-2007 06:03 AM
l2aine
05-06-2005 10:15 AM
ryoisaguri
04-27-2005 01:13 PM
allhopeislost
10-06-2003 06:34 AM
Rittmeister
09-23-2003 04:09 PM
