Idle way too high. Help...
i just finished dropping my sr20det in. It started right up with no problem but its idleing way too high literally around 3100 rpms and i need help on turning that down.
Thanks
Thanks
na if that was not hooked the car would not idle at all... make sure the screw is adjusted on the iacv
also make sure your throttle cable is adjusted properly
and last check any major vacuums
well i found the problem this morning it seems that my throttle is stuck open cause when i force it close it idles perfectly fine but when i let it go again it goes right back to 2500 rpms now cause it did play with the iacv, how do i fix this? do i need a new trottle body?
well i found the problem, when i took the trottle body off to clean it i noticed that the metal bar the spring is connected to was bent. so i bent it back hooked it back up and it worked perfectly. thanks for the help
BlackZenki82
SR
06-05-2009 09:08 AM
