How to run this wire???
I read the Raine info about the foglight mod, and I think im going to run the wire to the battery. How think should the wire be? and how should I run it from the fuse box to the battery without shorting anything? thanks.
I recently installed my silvia front conversion and was wondering if the fog light mod is the same concept raine had on his write up-I have a triple projector btw. The car doesn't have a FR FOG relay in the fuse box either, I guess I'd have to buy one.
BTW - no foglight relay = you don't have the OEM foglight switch either then?
Originally posted by l2aine
That would depend heavily on how much those Silvia headlights are wired into the factory harness. If the triple projectors were wired independently, then it would be easier to wire the fog seperately as if it were an aftermarket setup.
2. There's no foglight relay-there's a spot for it but there's no relay. What does the FL switch look like? There's a switch next to the rear windshield wiper buttons, but I don't know what purpose it does. I haven't taken the time to look under and follow the wire.
1. The wires are wired independently.
