How do i remove the Dash?
s13, remove the kick panels first, one clip and two screws, then remove the 10mm bolt at the base of each corner that is now exposed. Next, remove the lower cover below the steering column, the glovebox, the center console, radio and trim. All these are attached with either phillips screws or 10mm bolts. The top defrost grille snaps out and there are two 10mm bolts behind, remove those. Under the dash, driverside, remove two 12mm bolts securing the column to the support, then remove the gauge cluster shroud and the cluster itself, all phillips screws here. There is a 10mm behind the cluster, remove it. The frame behind the glovebox is secured with 10mm bolts as well, remove it. This is general for both models, but the whole process is simple. The only other catch is on S14s, there is a hidden 10mm bolt behind the passenger side door vent cover.
doogie240
07-26-2003 03:40 PM
