got money...need 11's (cont)
Old 12-13-2002 | 08:53 PM
LI S13 Blacktop's Avatar
Old 12-13-2002 | 11:16 PM
NightXCZ77's Avatar
No slicks, but what engine? S15? and also, tell me what all you have. I am not going to bash on you like others do to me all the time, I am just interested in what setup you have to run a 12....
Night
Old 12-14-2002 | 12:32 AM
suckit's Avatar
Originally posted by LI S13 Blacktop
Yea, exactly, without labor....if someone here is asking what they will need, my final #'s will be closer to the real cost...
i know how cheap i could do it for, and so do others, but we dont pay retail : )
i hit 12.8@109mph, with an SAFC. (stock motor, stock ecu, stock turbo, open diff), so whats your point?
but to be honest, retail on a new t28 is like 8-900, tec2 is 1750+tuning (2400total), and injectors are 4-500, so really, thats almost 3 g's + motor, 5ktotal, without suspension and everything, and only in the 12's....ya know.
that 3037 isnt going to fit the stock manifold, so add 1000-1500ret for the exhaust manifold to your price....
chipped ecu = blah
so for like under 5k i can make a car do 11's, but is that whats wanted? i dont think so, and i was being realistic on what it will cost....In MOST cases it wont be done by someone for less than 11k$.....
: P
Well labor is free so it doesnt matter but cost on materials is whats the difference.
Anyways the guy got the T28 for free and was running only 14psi and hit a 113mph. Im not sure what you were running but still impressive. As for the 3037 fitting on, it does as Ive tried it before using the factory lines and manifold. Also the chipped ecu is for 550cc/Z32 maf/ no speed limit and raised rev limit for 1/4 of your Safc. Its very realistic and affordable to go 11's if you dont care if its not pretty . More on the side of $3000+ and throw some cams in of course for some extra top end and you done. But like you said with everything else added up it still comes down to about at least 9k+ with miscellaneous stuff/labor and motor set.
Old 12-18-2002 | 06:42 AM
Night
cumon now...it says in my screen name s13 blacktop, i thought that would give it away
89 240 coupe- weight 2514lbs w/out driver (current)
S13 SR20det Blacktop
Greddy rspl Front mount IC
Greddy 2 row Aluminum Radiator
Greddy 3" downpipe
Greddy aluminum Oil pan
Apexi n1 3" catback...
3" straight pipe, no cat
Walbro fuel pump 255
Custom iron clutch, Clutch Specialties
Silvia Tach
HKS cam gears
Turbo xs bov
Turbo xs boost controller
Apexi Super-AFC
Apexi turbo timer
Apexi El boost guage
Autometer EGT, air/fuel, water temp, oil pressure guage's
Black sparco seat
17" tourismo rims powdercoated black
215/40 17" yoko parada's (street)
16" konig traffics white
225/50 16" Nitto 555R drag radials (race)
Tokico blues w/ intrax springs all around
battery relo to trunk
Hyrulianlink15
For Sale - Part Outs
03-11-2011 08:58 AM
rkcarguy
07-13-2004 06:01 AM
KinTako
12-16-2003 02:57 PM
JeromeS13
12-16-2003 09:25 AM
LethalKid69
12-11-2002 09:03 AM
Quick Reply: got money...need 11's (cont)
