gas octane
Old 10-15-2002 | 03:31 PM
spitz7985's Avatar
gas octane
what do u guys run? i've been running 93 octane but it is so damn expensive (like $1.86/gallon!). i put in regular (isn't it like 87 octane) once and my car was noticeably slower (at least i think it was), so i haven't put it in since. i know the nissan recommends 93 and i know the science behind the higher octane gas and how it is better in some engines. what do u guys run?
Old 10-15-2002 | 06:05 PM
boro240's Avatar
run whatever your ECU is programed for. i always fill up with 87. if you use higher or lower octane without proper engine management all you will do is throw off your timing and screw yourself over.
Old 10-15-2002 | 06:20 PM
malicex000's Avatar
i use 93 .... alot of people use 93... i hear you get better performance... very slightfull but u do hear about it... here in ny gas is about 1.69 for 93 at good locations... what company do u guys suggest ? i use hess and sunoco... is that good ?
Old 10-15-2002 | 07:19 PM
StanBo's Avatar
The 240 gets 93 and I stick to Amoco and the Shell next to my job. I stick with the big names when I travel. The name doesn't always mean you are getting the best quality. Remember these stations are franchises so they can do whatever they want when not being checked upon.
Old 10-15-2002 | 09:06 PM
malicex000's Avatar
so u suggest amaco ? i hear mobil has good gas too... i just want something suffuicient that will be good on the car and last long... some gas is just stupid and drains mad quick
Old 10-16-2002 | 10:39 PM
rbboyl's Avatar
Regulate
There is really not that much of a difference in performance between 93 and 87. Not significant enough for you to notice at least. I ran premium for a while but decided it wasnt really worth the extra money. The 240 really runs fine on regular. I usually try to stay away from the lesser known stations, like Getty, Gulf, Coastal, Wawa(yes, there's a wawa gas station around here), Gasteria, and the like.
jackyliem
05-16-2006 06:01 AM
Carparthookup
09-19-2005 08:34 PM
Suhster85
02-12-2004 03:23 PM
crimsontide240
11-04-2003 05:05 PM
calidrifter
Canadian Forum
19
09-22-2003 09:44 PM
