EGR block-off plate.
Old 06-26-2007 | 08:37 PM
clubredsilvia's Avatar
EGR block-off plate.(new problems)
Does anyone have a printable (correctly-sized) template for an EGR block off plate (KA-DE)? I knew i've seen one around here, but i can't find it anymore. I bought an E-Bay plate for dd, but my new project car needs one and i'm broke.... , thanks in advance.
Old 06-26-2007 | 08:45 PM
i don't but what i did was take the egr valve off and trace it onto a 1/8" thick piece of sheet metal and cut it with a grinder. it took about 15 min to make, but you'll need shorter bolts if you use a 1/8" plate.
Old 06-26-2007 | 09:48 PM
get some textured paper and a crayon, peel the paper off the crayon and rub over the textured paper when it's laying over the egr portion of the manifold. it doesn't have to be exact
Old 06-27-2007 | 12:10 AM
ha ha i actually cut my own gasket for my egr block off, it was fun...
Old 06-27-2007 | 06:48 AM
Durdan's Avatar
OR... you can just unthread the pipe, throw in a nickel and reinstall the pipe. doesnt clean things up at all, but it blocks off the EGR still
Old 06-27-2007 | 07:20 AM
i used high temp silicone. the egr valve is on the intake manifold so it really doesn't get that hot.
Old 06-27-2007 | 07:37 AM
-is it necessarily bad to make a block-off plate out of aluminum? Its easier to cut/drill and i have a sheet of 1/4 aluminum plate.
Old 06-27-2007 | 08:49 AM
no no i have an actually block of plate from ebay that cost about 5 bucks man at the time
i just made a gasket to get a even tighter seal... years before that... what i did was take the pipe off the egr, installed a plug and then i screwed the pipe back in and crimped it. sealed very tightly... but like durdan said it still wasn't clean behind there.
Old 06-28-2007 | 12:15 AM
BigVinnie's Avatar
Weld a dime to the egr valve inlet and call it a day.........
Old 06-28-2007 | 07:06 AM
-i bought a plug that i though was the right size from home depot. Didn't fit, so i cut the collared tube that goes into the header about an inch long, JB welded a dime to the flare. Also made a block off plate out of a piece of aluminum, sealed with rtv.
-now, my car runs fine, but after driving for about five minutes, it drops idle from 800 to about 250-300 until it konks out. I think it may be the vacuum lines? I took out the egr tube, EGR valve and a little ufo -shaped thing that was attached to the EGR valve by a tube.. Was i supposed to remove this, and am i supposed to plug the vacuum lines or not.
Old 06-28-2007 | 09:07 AM
YUP!. any vacuum line that is not being used by FPR, Bov etc needs to be plugged/capped/whatever offed
back of your engine should look like so
Before
After
note: i didn't put the plate on it in this picture
Keyword
EGR block off emissions removal
Old 06-28-2007 | 09:57 AM
Durdan's Avatar
dimes are:
A) too small
B) not heat resistant
nickels are:
A) just the right size
B) extremely heat resistant.
C) what i tell everyone to do, so i must be right
Old 06-29-2007 | 05:28 AM
^^^alright, i think i might do the nickel swap if i can save up enough money.
-Anyway, i found out why my car would stall out. Apparently when i was turning wrenches on the EGR, i smacked/cracked the black tube that runs with the hard lines and goes from the bottom manifold to the brake booster(?). I couldn't figure it out because i would start my car and run around and couldn't see what it was before it stalled.
Old 02-29-2008 | 07:02 PM
DcrPrz's Avatar
are you guys talking about that brown pipe that goes fron the intake mani to the exhaust mani, i am having problems with my new header and that pipe lining up, can I just take it off and block it with the nickel without hurting anything?
Old 02-29-2008 | 08:19 PM
yes, don't forget to cap off the (i believe 2) vacuum lines for the egr valve and egr solenoid.
