Disappointing Dyno results
Well I finally cleaned up my Tune, With the new computer and well when they said the turbo is only good for 450hp they were not kidding. I just kept the boost at 1.57 and pulled what you see below. I will now throw a GT3567R on there and see what comes up. save picture as to see it better.
Well Actually the Turbo kit will be forsale very soon, Yeah Bigvinnie I expected a little more from the turbo but what can you do. I am still happy that I maxed it out.
Haha the turbo only has 8890 km on it full kit will be forsale
TD-06 25G 10cm
Greddy manifold
Greddy TypeR wastegate
Front Pipe
TD-06 25G 10cm
Greddy manifold
Front Pipe
Here is a list of Mod’s From Engine to tires
Engine:
Tomei Double valve springs
Tomei Solid Lifters
Tomei RAS
Tomei 270 Cams with 12.5mm lift
Tomei Adjustable Cam gears
Tomei Stock bore pistons
Tomei H-beam Con Rods
Tomei Balanced Crank
Tomei 1.2mm Head Gasket
Tomei Oil Pump
NISMO bearings
NISMO water pump
Greddy 7qt oil pan
Sard FPR
Sard 850cc injectors
NISMO Fuel pump
Drive Train:
Emotion R R33 Transmission kit w/ shift kit
R33 GT-R OS Giken cross mission w/ large input/output shafts
OS Giken twin plate clutch
R33 Propeller shaft
R33 GT-R drive shafts
NISMO 2 way LSD
Peripherals/Misc;
Greddy TD-06 25G 10cm turbo
Greddy exhaust manifold
Greddy Type R Wastegate
Greddy Intake manifold (surge tank)
Greddy Type R BOV
Greddy FMIC 2 core
100mm Turbo inlet pipe
Speed Factory One off Oil catch can
Stainless steel Radiator overflow
3 Core Brass/copper radiator
HPI engine Damper
NISMO tower bar
Electronics;
Apexera Power FC D-jetro w/ commander
Data log (Australian made)
Greddy Profec A boost controller (Stepping motor type)
Defi Meters: Exhaust temp, Oil temp, Water Temp, Boost Pressure, Oil Pressure, Fuel Pressure, Tachometer
Yupiteru Car starter-turbo timer
Body/ Suspension:
Carbon Fiber Hood
Stock NISMO body kit
Safety 21 8 point roll cage
Work Emotion R kai Rims 17x9 R 275/50/17 Nittos 17x8 245/45/17 Nittos
All adjustable link suspension parts are JIC pillow ball type
Aluminum Sub frame bushings, Mission mounts, and Engine Mounts/with urethane
R33 GT-R brake upgrade
Kakimoto Full N1 Mega Exhaust
Engine:
Tomei Solid Lifters
Tomei RAS
Tomei Oil Pump
NISMO bearings
NISMO water pump
Greddy 7qt oil pan
Sard FPR
NISMO Fuel pump
Drive Train:
R33 Propeller shaft
NISMO 2 way LSD
Peripherals/Misc;
Greddy Type R BOV
Greddy FMIC 2 core
HPI engine Damper
NISMO tower bar
Electronics;
Body/ Suspension:
Carbon Fiber Hood
I don't feel like doing the math right now........ I'm getting ready to go to a raging kegger......
