Cross Drilled Rotor install
Old 06-26-2005 | 08:04 PM
BigVinnie's Avatar
Thought you guys might want to see the damage report on my rotor install found out that when I took off the right front the caliper was locked into the old rotor. You can literally see the steel shaved from the rotor......
Old 06-26-2005 | 08:06 PM
BigVinnie's Avatar
Installing the new rotors was simple...
Take a clamp to each caliper to open them up, that way you don't have to bleed the lines.........
These are the brand pads that I am using.........
Old 06-26-2005 | 08:07 PM
smokie700's Avatar
Nasty
Old 06-26-2005 | 08:09 PM
BigVinnie's Avatar
This is what it looked like after I put the new rotors on........
I was able to free up the frozen caliper to rotor with some WD40...
Then I pushed on the pedal a few times while KEV got the grime out. " So technically a little bleeding was needed to the right front caliper".....
It brakes on a dime now......
Old 06-26-2005 | 08:11 PM
BigVinnie's Avatar
Next week I'll have pics of my KYB AGX and TEIN install.
I only get 2 to 4 hours to use the shop on weekends......
Old 06-27-2005 | 04:09 AM
SHIFT_Sideways's Avatar
nicceeeee i wish i had cross drilled rotors!
Old 06-27-2005 | 05:57 AM
very nice, i just got some slotted drilled rotors the other day.
What kinda tool did u use to take out the large phillips screw that holds the rotor in place.
I was simply going to put a lil heat on it and use a very large phillips
here are mine
Old 06-27-2005 | 08:17 AM
BigVinnie's Avatar
here are mine
Actually you might find this kind of funny but the Non ABS don't have screws. The rotors came right off, "Well the front rotors came right off at least", you can see in my first pic the rotors originally didn't come with LOCK SCREWs. The rear discs were a ***** to work with and do have lock screws and cotter assembly holding it in place came right off though, I thought I would of been out in an hour it almost took 2 to get all the work done....
I used a 90degree pnuematic drill with bit......
How much did you spend, I only paid $90 for my full set of rotors............
Old 06-27-2005 | 08:00 PM
they were frree i got them from a friends recked 240 for fixing his car
they were never used
what are some good pad to go for
Old 06-27-2005 | 08:08 PM
BigVinnie's Avatar
Well as far as performance pads go, I bought the CBK semi metalics for the front. So the front end would stop on a dime.
I bought cheap organics for the rear so that I can do standstills, drifting, and burn mmmmmaaaaaddd rubber, I didn't wan't the rear to lock up at all. But rather just ride smooth especially on the release of e braking............
Just my 2 cent's.
But if you really want to stop on a dime you can go with the z31 dual caliper upgrade that fit the s13. Bigger brakes that you can buy cheaper pads, like raybestos brake pads..........
Damn you can never beat free rotors, you lucky S.O.B..
Just kiddin' on the SOB
Old 06-27-2005 | 08:29 PM
very well, im also getting steel braided lines and converting to dot5.
Old 06-27-2005 | 08:32 PM
BigVinnie's Avatar
DOT 5?????? I only thought there was a mix of DOT 3, DOT3/4, and DOT4, didn't know that there was a DOT 5..........
The company called Magnum who I bought the rotors from on ebay also sells steel braided brakelines in the set of 4 for 69.99, I think they were asking for $15 shipping.
Old 06-27-2005 | 11:56 PM
yea man when i seen it , it was new to me. my sponsor had some. its purple and redline makes it. he had to waste an entier bottle which cost like 20 bucks, to flush the system. It also works very very good under hard braking on autocross style courses.
yea i seen those braided lines. im getting them I also read about putting a z32 mastercylinder into a 240. I might be doing that as well.
cheap mods that make a difference is what i call it lol.
Old 06-28-2005 | 10:04 AM
BigVinnie's Avatar
LOL
jdmsoarer
12-14-2003 04:20 PM
jdmsoarer
12-07-2003 06:51 PM
jdmsoarer
10-06-2003 05:33 PM
E Spin
08-07-2003 09:20 PM
flstseminolejd
06-16-2003 03:52 PM
