Crankshaft position sensor
Old 09-30-2008 | 06:05 PM
smoken805s14's Avatar
IS there a crankshaft position sensor on the s13 models? i have a s14 but when i got the 96 crankshaft sensor my mechanic said it didn't fit...i know i have an older tranny cause i replaced the slave and i have to get the s13 one...i need to fix this problem cause i can't pass smog...any help please...thanks
Old 09-30-2008 | 06:18 PM
its located inside the dizzy ... so if the CAS is bad.. you need to 1. check the wires going into the dizzy and make sure they are not broken
2. remove the distributor and use it as a door stop and get a new one lol.
Old 09-30-2008 | 06:48 PM
he lied to you lol s13 and s14 slave and master are the same infact even s15 is slave is the same
Old 09-30-2008 | 08:09 PM
so its located in the distributior?
BmoresZenkiS14
06-27-2006 09:29 PM
smokin240
05-19-2006 03:03 AM
Enlefo
01-06-2006 01:57 PM
CowboyTurbo
07-28-2005 08:41 PM
SoloDrift1
03-11-2003 06:21 PM
