Clutch Adjustment
Old 11-16-2003 | 06:41 PM
ryan15's Avatar
Clutch Adjustment
could some one help me out with adjusting my clutch, i have no idea where to even start.
Thanks
Ryan
Old 11-16-2003 | 10:09 PM
You mean clutch pedal adjustment?
Old 11-16-2003 | 10:14 PM
BeteNoir's Avatar
Yes clarify please.
Old 11-16-2003 | 10:20 PM
ryan15's Avatar
im not really sure but i think that might be it.
OK here`s whats up, you have to let out the clutch pedal almost all the way untill it engages.I hope that helps
Ryan
Old 11-16-2003 | 10:24 PM
0k there is to much play in the pedal. Check this site out...its really helpful http://**********/faq/index.html then go to clutch pedfal adjustment, that should solve ur problem
Old 11-16-2003 | 10:33 PM
BeteNoir's Avatar
Ryan
And this is a bad thing??
Neway.... follow the clutch pedal arm up to the push rod that slides into the master cyl. There is an adusting nut behind the bracket. Back it off a few turns and rotate the push rod clockwise (from driver's seat) to adjust. Find the right setting and lock the adjusting nut.
You may also need to bleed the system if the pedal feels too soft.
Actually, just do what he /\ said.
Old 11-17-2003 | 10:25 PM
ryan15's Avatar
ight it was actually counter clockwise to fix the problem it was really easy thanx for helping me out
Ryan
Old 11-17-2003 | 10:26 PM
Awesum Glad we can help ya out
Old 11-17-2003 | 10:39 PM
BeteNoir's Avatar
Hey its not my fault that my mom didn't teach me my clockwise from counterclockwise. lol
Glad to be of help.
92nissan
09-23-2007 08:58 PM
Alteus
10-17-2006 09:48 AM
resonancevil
11-05-2005 05:18 PM
epoxy
01-20-2004 02:20 PM
stannyboy
09-30-2003 08:55 AM
