clicking noise when pushing down clutch
I just installed a ACT clutch for my car. Probably about 2-3 months ago. Recently, when i push down the clutch, i hear clicking noises. like pushing-a-pen clicking. And when i push down the clutch, there is like 5-7 clicks as i push it down. Anyone know what the clicking noise could be?
sounds like it is from under the dash or under the car????
if its under the dash... check teh return spring or soemthin that moves with the pedal.
under the car... did you replace the throwout bearing????
I assume you did.. maybe the shift fork has a groove worn into it or no lube left or somethin.... you will have to hunt around. chances are it is not your cluth or pressure plate.
i guess that really depends on what exactly is making the noise.... if it is a groove then the groove will only get bigger or start to stick, if it is just a pivot ball without grease then you will prob just have to deal with the noise.... either way you shoudl investigate and fix when you have the time.
