Check engine light???
Old 09-14-2006 | 11:31 PM
2fst4u's Avatar
I ordered a JDM cluster for my 1995 automatic 240sx. I put it in myself today and now my check engine light pops up. Here is exactly what I did. First I disconnected the battery, then I took my old cluster out and dropped in the new one in. I noticed the JDM cluster was missing some bulbs so I took the bulbs from my old cluster and put it in the new JDM one. SOme of the lights that was missing from the JDM cluster was o/d (overdrive) I needed overdrive because mines an auto. ABS, Airbags and cruise was missing. So I took the bulbs from my old cluster to place it in. Put the battery back in and now I noticed the service engine is on and also, when I push the cruise control button the green cruise light in the cluster does not go on either. So I thought there was something wrong with the cluster, so discconnected the battery again, switch the bulbs back into the old cluster and and installed the old cluster. Started the car and the exact same problem as the new cluster. Cruise light does not work and the Check engine light is on. Did I mess something up? I even swiched the cruise light with the service engine light to make sure the cruise light was not burnt out, which it wasnt. If you guys can help me that would be great. Thanks
Old 09-16-2006 | 11:03 PM
2fst4u's Avatar
Anyone with any suggestions?
Old 09-17-2006 | 01:03 AM
re037's Avatar
id read the codes off the ecu, and start from there...
Old 09-17-2006 | 11:32 AM
i think you have to swap a few sensors on the tranny. any particular reason you wanted a jdm cluster? i only see it as a burden to have kph reading
Old 09-17-2006 | 01:27 PM
2forties's Avatar
Banned
The JDM cluster set off the check engine light because of the transmission and the reason you have the check engine light also going off on your old one is because you now need to clear the check engine light from your ecu. I have no idea why your cruise light wont work.
Old 09-17-2006 | 02:12 PM
2fst4u's Avatar
Thanks for the reply guys, How do I clear the check engine light from my ECU? Would dissconecting the battery for a few minutes might work?
Old 09-17-2006 | 02:24 PM
follow the guide on www.ka24development.com ka-t.org
Old 09-17-2006 | 02:26 PM
2fst4u's Avatar
I just clicked on the link you posted and it doesnt work
Old 09-17-2006 | 08:02 PM
2forties's Avatar
Banned
http://www.ka24development.com/ecu_codes.html is the link
drew935
West Coast/Hawaii
03-29-2004 12:36 AM
OWU Joe
02-29-2004 11:04 PM
neolikquidx
10-16-2003 11:08 PM
neolikquidx
10-15-2003 01:18 AM
neolikquidx
06-16-2003 09:44 PM
