Bushings (s14)
Bushings (s14)
I was just looking under my and seeing that most of my busgings are worn out so i have been serching all day find out what options i have in bushings and i have come up with this list. did i forget something? is there maybe a more complete kit than the energy suspension kit
Energy suspension hyperflex bushing kit
• Front Control Arm Bushings
• Front Sway Bar Bushings
• Rear Sway Bar Bushings
• Front Strut Rod Bushings
• Tie Rod End Dust Boots
Energy Suspension
• Front Tension Rod Bushing Set
• Rear Sway Bar End Link Stabilizer Bushing
Whiteline
• Rear Upper Control Arm Bushings
• Rear Lower Control Arm Bushings
• Rear Camber Correction Bushings
• Rear Nissan Sub-Frame Align and Lock Kit
• Front Lower Control Arm Bushings
• Sway Bar D bar Bushings
• Front Sway bar End link donuts
Cusco
• Motor mounts
Tanabe
Transmission Bushing Set Drift Spec
Sustec Rear Sub-Frame Collars
Prothane
Front strut rod bushing kit
Tie rod boot kit
Total kit coming soon
Peak Performance
• Transmission Bushing Street
• Transmission Bushing Pro
Kazama
• Solid Engine Mounts
Nismo
• 3pc SR20DET engine mounts
• Rack pinion bushings
Phase 2
• Aluminum double subframe bushing kit
Energy Suspension
Whiteline
Cusco
• Motor mounts
Tanabe
Prothane
Tie rod boot kit
Peak Performance
Kazama
Nismo
Phase 2
There's a lot you missed if you're going for a complete list... URAS tranny mount, RS-R has a kit now too... etc.
Also the Nismo set isn't really a set- people just sell it that way. The Nismo motor mounts work for both KA and SR; same for the Nismo tranny mount.
Gearhead_42
04-07-2006 06:29 AM
justinmc
05-09-2005 05:51 PM
