air bag controller
air bag controller
I know i need one, a guy i know is parting out a car, so where is the airbag controller located and what does it look like. I tried searching through some nissan parts books and some "chilton" styled books but couldnt find anything
That is the place. Right in the middle of the rear seat bottom. Only problem is you need a special tool to get the bolt out. You need a TT50 torx bit.
Controlers out of both obd1 and 2 are the same. The part in the bottom right corner is the control module cover. Also secured with a TT50 bolt.
No, you can't. The airbag controller is a device that records and saves the accident information. It stores the data on which air bag get blown out in a crash.
For example, if you blow your dash bag the computer knows this. You put in just another new dash bag, it will never blow again. The controller just sees a blown airbag, not a good one. You have to change out the controller as well.
I've replaced 10-20 airbag setups in a lot of different make and model cars.
Controlers out of both obd1 and 2 are the same. The part in the bottom right corner is the control modules cover. Also secured with a TT50 bolt.
not sure if I am following the OP question completely, but if you ever question something and need an better idea of where something is located. roll to the parts counter at nissan ask em about said part and have them give you the print out. generally it shows what you need (sometimes it doesn't)
Now personally, I don't like air bags. IMO, it's like getting in the ring with Mike Tyson and saying OK Bro come at me. Knowing that you have no chance in blocking a single punch.
sw20fj40
09-14-2005 06:26 PM
captainmodify
09-06-2005 09:20 AM
