89 KA-T wont run
Old 11-16-2008, 07:39 AM
240Boogyman's Avatar
89 KA-T wont run
got a 89 it will start and idle fine but as soon as you give it gas it cuts off. checked the ecu and the only code is 14 (speed sensor) the air flow sensor is good and the tps has been replaced...what could it be?
240Boogyman is offline
Old 11-16-2008, 09:51 AM
shaban's Avatar
it could be a million different things, need more details. what's it do when you give it gas? does it rev then rpm dips and shudders then cuts off?
shaban is offline
Old 11-16-2008, 11:17 AM
you can floor it and it shudders if you try to ease in the gas it just cuts off. hold it on the floor and it shudders around 3000 rpm
Old 11-16-2008, 12:34 PM
shaban's Avatar
vacuum lines, maf, injectors, 02 sensor, check those out first.
shaban is offline
Old 11-16-2008, 12:58 PM
wouldn't the o2 send the ecu a code and if not how do i check it...all the lines are hooked up and the maf is good, already checked those.
Old 11-16-2008, 12:59 PM
and whats the best way to check the injectors
Old 11-16-2008, 04:19 PM
pull them out. Injector o-rings could be the culprit
silviaks2nr is offline
Old 11-16-2008, 04:42 PM
O2 has nothing to do with it........... i didn't run one for the last 3ish years.
OBD1
I didn't want the O2 messing with my tune at any point.
needs more info
Biggamehit is offline
Old 11-16-2008, 08:53 PM
also consider ecu, could be bad.
Old 11-16-2008, 09:31 PM
shaban's Avatar
I would think if his ecu is bad the car wouldn't start...?
shaban is offline
Old 11-16-2008, 09:44 PM
240smoke's Avatar
Yeah it could still start. Def check injectors and o-rings. Check the resistance on the injectors to make sure they are the same all the way down.
240smoke is offline
Old 11-17-2008, 12:19 AM
........... yeaup ECU's are funny characters.
do an ECU diagnostic OP..... there are direction in the how to section.
Old 11-22-2008, 01:29 PM
checked the codes on the ecu only one that comes up is vehicle speed sensor
Old 11-22-2008, 06:08 PM
re check all couplers and check you AICV
Old 11-22-2008, 08:15 PM
if it starts and idles fine you can automatically ignore half of the posts so far. i wont say what half though. what i'd like to know is when the problem started and if you have checked for codes since you replaced the tps. i have more questions but these two will do for now.
jramosthe1st! is offline
Quick Reply: 89 KA-T wont run
