3 point racing harnesses install.
3 point racing harnesses install help.
Okay,
I'm going to buy a pair of 3 point racing harnesses, and was wondering if anyone has used them when there stock seats, and it was comfortable? and if so, how you installed them?
Is it possible to use 4 point?
i have simpson 5 points in my 96. MAKE SURE YOU MOUNT THE BELTS CORRECTLY OR IT COULD KILL YOU. i dont drive with mine on cause it has to be tight against you to work properly and then you are severly limited in movment. it makes it hard to look around you cause you cant lift a shoulder. i still have my stock 3 point installed and i use that every day but i use the 5 for spirited driving. oh and i do have my stock seats
So it's not a smart Idea to do it if i'm going to be driving it daily? The reason is that the driver side seat beal motor doesn't work, or it just won't move. So I figured I just get these because they're nicer, instead of always having to connect and disconnect it from the top.
CharlesJ
11-28-2007 08:24 AM
williewet3
07-22-2006 06:27 PM
BigVinnie
07-21-2005 10:35 PM
