3.5 SE will not start
Old 02-08-2002 | 11:29 AM
cbarrios28's Avatar
3.5 Altima SE auto with pop charger as the only mod. Wifey started it this morning drove for a 1/4 of a mile and in stoped. Started it again drove back to the house and it stoped. About half an hour later I tried to start it no go. It turns, starts and it fizzles out in about a second. Accelarator does nothing, and it is not blowing any smoke. Any ideas? One more thing should I take off the pop charger before I take it to the dealer?
Old 02-08-2002 | 11:35 AM
ALTIMA420's Avatar
definately remove air filter before going to dealer. Did you check all your sensor wires around air-box?
Old 02-08-2002 | 12:00 PM
jaltima's Avatar
You must take off the cai before taking it to the dealer or else I promise they will think up a way to make your problem be a result of it! I would leave it off till spring.
Old 02-08-2002 | 12:35 PM
flarearrow's Avatar
Sounds like a vacuum leak somewhere. Is your popcharger installed airtight???
Old 02-08-2002 | 12:36 PM
downhillracer's Avatar
that happend to a friend of mine it was the sensor make sure they are AIR TIGHT! or the ecu will not be happy
Old 02-08-2002 | 02:51 PM
cbarrios28's Avatar
Just took it to the dealer. Let's see what happens. I had the pop charger for about two months with no problems. Service engine light goes on.
Old 02-08-2002 | 10:00 PM
cbarrios28's Avatar
Just got the news from the service advisor. I did take of the pop cahrger before the tow truck took it away. It was the air meter or MAS. The car has only 6000 miles. Could the pop charger have had anything to do with this? Maybe the MAS is not heavy duty enough to take the increased air flow?
Old 02-09-2002 | 08:21 AM
PaceCar's Avatar
Vibration may have been the culprit. SCC had a similar problem with thier subaru project and linked the problem to vibration from the intake. They went through 2 or 3 of them before switching back to the stock box. But you never know you could have just had a faulty one.
Old 02-10-2002 | 02:44 AM
HondaKillah's Avatar
Damn,that sucks...so no mods for you huh?
Old 02-10-2002 | 11:59 AM
cbarrios28's Avatar
My pop charger was on tight. No vibration at all. I will put it back on as soon as I get the car. I hope that is not the problem.
Old 02-10-2002 | 12:46 PM
fanatic's Avatar
Ex-Mod :)
Well, I hope you get it fixed soon.
KAMAKAZI 13
10-24-2006 06:08 AM
Dougbo9807
12-22-2005 08:40 PM
dak2007
10-28-2005 01:18 PM
tegg_gsr
02-24-2005 10:45 PM
Slidin240
12-07-2004 03:57 AM
