24e, 24de?
Old 06-30-2005, 08:40 PM
  #31
JoxteR's Avatar
Originally posted by JoxteR
my check engine light came on a few days ago and i got it scanned and it said one of the reasons it came one was because the, "EGR fails to change EGR temp sensor resistance enough or resistance changes too slowly." and earlyer in this thread it was said i could take that out so would that be hurting the car in anyway or would it be fine and my check engine light would turn off?
so will someone help me out with this question?
and also is taking out all the emissions stuff gonna hurt my car in any way?
JoxteR is offline
Old 06-30-2005, 10:00 PM
  #32
BigVinnie's Avatar
What you want is the AC Delco part number (2171767)
This is the egr temp sensor controller this is what you need for your EGR.
You can get it at advance autoparts, or rock auto for about $140
You have too have this item working properly including the EGR. Thats why the EGR block off method is used. The ECU reads each individual sensor, if one sensor isn't working properlly it completly shifts the fuel curve and the TTP. Chances are you will run rich... I am completely against the removal of smog emissions unless you have had the ECU reprogrammed for it to respond without those emissions parts with sensors.
BigVinnie is offline
Old 07-02-2005, 02:28 AM
  #33
JoxteR's Avatar
so if i decide to remove all emissions equipment i should get my ecu reprogrammed? how much will that cost?
JoxteR is offline
Old 07-02-2005, 02:32 AM
  #34
BigVinnie's Avatar
$400, or $500 from enthalapy have them do the work.
Old 07-02-2005, 02:39 AM
  #35
JoxteR's Avatar
thats quite a bit of money, will it be hurting the car if i dont get it reprogrammed? and im not familiar with enthalapy.
JoxteR is offline
Old 07-02-2005, 11:05 AM
  #36
BigVinnie's Avatar
It doesn't hurt the engine it hurtds performance if you want more knowledge on enthalapy you can go to the Zilvia forums......
shane_lxi
05-15-2005 11:19 PM
shane_lxi
05-03-2005 02:48 AM
alphadrago007
06-27-2004 12:37 AM
Project Cheap13
06-22-2004 06:24 AM
Quick Reply: 24e, 24de?
