115?!?!
Old 09-26-2002 | 11:00 PM
SoloDrift1's Avatar
115?!?!
topped out at 115mph??? WTF?!?!
Old 09-26-2002 | 11:05 PM
rudeboy's Avatar
you need NOS man! two of em!
just playin.
rev/speed limiter.
get chipped up or cut some wires.
Old 09-27-2002 | 08:14 AM
Import Fanatix's Avatar
Yeah man, the only way to get around that is as rudeboy said. I hit that all the time man, and also the rev limiter at about 7000. The car is limited all over the place man. Need to get chipped is the safest way or SR that Bad Boy.
BTW does the SR also have a limiter?
Old 09-27-2002 | 09:08 AM
Justin.b's Avatar
YOu can get around the speed limiter by disconnecting the speed sensor - but then you lose your speedometer.
You can wire a switch in line so that you could do it only when you wanted to.
Apexi rev/speed meter also has speed limit removal funtions. I don't know if this will remove the 4th gear rev limiter though.
My 4th gear limiter seems to let me go fater than the 5th gear speed limiter though. Either way, it's a reminder that I really don't want to get busted at those speeds so I usually slow down.
-Justin
www.saltgod.org
Old 09-27-2002 | 12:01 PM
agressiveracing's Avatar
welll i can keep going in 5th gear..
what rpm does the speed limiter kick in
Old 09-27-2002 | 02:02 PM
rEvVoMaNiAc's Avatar
most probably a speed limiter. most of those aren't even factory installed. dealerships sometimes reprogram the ecu with a speed limiter so they can get away with putting on cheaper tires that would bust at higher speeds.
my altima does that at 120... i feel it pulling nicely, even in the triple digits... then abruptly, it'll stop pulling and i'll level. JWT HERE I COME!
Old 09-27-2002 | 02:11 PM
Justin.b's Avatar
Umm... speed limiters are from the factory.
If you know a dealer around here that's re-romming ecu's I'd like to meet them. I only know of one Nissan tuner in the US that will touch the things with any success.
AFAIK, the factory speed limiter on the SE was ~117. There's not a speed limiter in 4th, in 4th it's a rev limiter. I'm not sure exactly where it is, but it probably lets you get a little over 117. At these speeds, I'm usually watching the road instead of the tach.
-Justin
www.saltgod.org
Old 09-27-2002 | 02:23 PM
Ryan's Avatar
No speed limiter for me.
Old 09-27-2002 | 05:23 PM
then why is it that other '99 GXEs don't have speed limiters and mine does? if they all came limited from the factory, then they'd all BE limited, obviously.
Old 09-27-2002 | 05:57 PM
stockride's Avatar
BWAHAHHAHHAHA my alty goes past the 120 mark, biyotch!
but it sure takes me a damn long time to get there, lol!
Old 09-27-2002 | 06:56 PM
Don't worry a little rom tuning or a little sr20 swap can help take care of it all. The speed limiter is as Justin Said, factory installed, not dealer installed.
I know the rev limiter is like 7200 or so. SO that might be the cut in 4th, but i don't get all my speed in fourth, gotta go to 5 to get to the end.
Old 09-27-2002 | 09:23 PM
rudeboy's Avatar
i thought all cars in japan came with speed limiters
Old 09-27-2002 | 11:44 PM
battlestylespl's Avatar
most cars in japan cut out at 180klicks...which is ~ 117..the silvia/180sx cuts out then.
Old 09-28-2002 | 05:09 AM
Then I guess we'll need a little ROM tuning with the SR swap also then. Is a chip or losing the speedo the only was to bypass the limiter?
Old 09-28-2002 | 10:20 AM
boogeyman's Avatar
me too
