Windshield Wipers won't work
Old 08-24-2009 | 11:36 PM
schmitty's Avatar
I was just wondering if anybody else had the problem of the windshield wipers won't work i don't think it is the motor because there is no voltage getting to the motor. Any ideas???
Thanks
Old 08-25-2009 | 04:21 AM
USMCDrifter's Avatar
Did you check the relay/fuse? If you did, check the switch.
The wiper setup is not complex at all! Even on BMWs, it's pretty much a parallel circuit with an open/close switch.
Old 08-25-2009 | 06:51 PM
Preston's Avatar
Check the fuse like he said...and check the accesory relay 1...behind the dash fuseblock...something else works off that relay too I can't remember, but that relay was bad and caused the wipers and something else not to work...if you have no voltage to the motor you need to backtrack. Start at fuse and work forward.
1SXY240
05-28-2010 01:29 PM
supra33202
09-26-2008 02:45 AM
ryguy
01-28-2008 01:12 PM
matt99r6
02-13-2005 03:09 PM
ixcocoyxi
10-29-2003 08:12 AM
