s13 flip up headlight options
Just as an idea, has anyone thought of using the SMAD (raceonusa knockoff of the supermade) headlights to retro J30 projectors into and then using plexiglass to act as a front lens to keep the projectors nice and clean? Thats my plan at least.
This site is mad expensive, but the LED's are Sick.. especially the brake lights, here's the head light:
http://www.clearcorners.com/products...0sx1/f_lowpro/
Here's the brakelight:
http://www.clearcorners.com/products...0sx1/r_hbtail/
clearcorners is weak. Their stuff is nice, but all can be had for cheaper with some simple DIY. www.HIDPlanet.com/forums has more info on lighting than you can shake a stick at.
personally i would make totally one-off lamps, using the custom formed lexan lenses. make the housing using some sheetmetal, fiberglass and filler. retro in some bixenon projectors and halogen fog projectors and have an amazing setup!
silviaks2nr - Well, I plan on purchasing the left-overs from NASA and fabricating a nano-tube structure to hold them in place powered by nuclear fusion
Thanks Phantom, i'll check that ish out, Cost effective is sexy
#26
Im seriously thinking of going silvia front end (either s13 or kouki s14) and making my own complete headlight housings. This s13 popup space issue is total bull****. There are like 3 projectors I can fit in em without losing popup function, and maybe one is bixenon.
#28
flush mount lights give you alot of extra room for fitting projectors etc. you could even extend the lenses down part of the bumper to give you extra depth and foreground lighting. similar to what you see on some fc rx7s
reminds me of a ferrari f40
