Gauge cluster/lower harness
Old 02-08-2010 | 11:42 AM
jbt_92's Avatar
So my Gauge cluster lights up, the clock works, and the gas gauge partly works.. But my speedo, tach, and temp do not. I'm guessing I need a lower wiring harness but I have a s14 motor and tranny so I was wondering if the tach would work with the newer motor And tranny. Do I get the harness from a s14 or s13? Maybe it dosnt matter. Any help would be greatly appreciated.
Old 02-08-2010 | 07:05 PM
its not a lower harness.. you must manually wire the body harness wires and or get the clip from a newer S13 that features a DE motor.
this is part of the setup from converting from sohc to dohc as the soch used a analog signal. The newer setup uses a digital signal.
Old 02-09-2010 | 10:57 AM
jbt_92's Avatar
It is the dohc one but from a s13..
Old 02-09-2010 | 04:54 PM
start over....
what exactly did you do to the car.. im confused.
Old 02-09-2010 | 09:05 PM
jbt_92's Avatar
well i got the car as a shell. Then I got the motor and tranny from a s14. Never had the lower harness. The gauge cluster was already in the car, but nothing works but the fuel and lights.
Old 02-10-2010 | 07:15 AM
Jaescrub's Avatar
sounds like 1 your cluster just craped out on ya or two you need the speed and rpm senser off the sohc trans plugs right in wire it up. When i was still rocking the sohc motor and my trans failed on me i got one from a 93 dohc but cuz my gauge cluster was from a sohc car i had to swap out the sensers from my sohc trans and put them in the dohc trans and then everything worked.
md66948
02-09-2006 10:48 AM
accel junky
10-05-2005 09:37 AM
kramsuey2268
11-16-2004 08:08 AM
kramsuey2268
11-15-2004 09:56 PM
BMadd
03-20-2004 03:49 PM
