whats needing for the SR swap?
hey guys i know your sick of hearing about this but i want to make sure im getting everything for the SR swap and i wont forget anything. heres the list so far
SR20DET Red Top
FMIC
BOV
Downpipe
3in exhaust
fuel pump
fuel filter
radiator,
eletric fan
thremostat
clutch kit (if needed)
motor mounts (if needed)
ECU
Harness
Thats all i can think of now if i forgot anything else just throw it up here. thanks
SR20DET Red Top
FMIC
BOV
Downpipe
3in exhaust
fuel pump
fuel filter
radiator,
eletric fan
thremostat
ECU
Harness
no you will also need
2x heater hose adapter 5/8-3/4
1x power steering lines (if sohc-sr swap only)
1x egr plug from nissan for the emmision system that interferes with steering column
1x airfliter assy (unless you got the stock one w/ clip
1x oil filter
custom a/c mount
a length of 14 gauge single pair shielded wire to extend maf sensor
common sense
beer
cigarettes
trust me i tried it w/o the beer...not recomended
do you have a clip or a motor set...that would simpify things
1x oil filter
custom a/c mount
common sense
beer
cigarettes
240sxwanting
04-02-2004 06:41 PM
