sr20det water pump, aftermarket?
i need a new waterpump for my sr20det...i did a search and i ONLY found a hi capacity waterpump from JUN. i was wondering if there are any other waterpumps that run cheap. im thinking around 100-150. the cheapest stock water pump i found was from phase2 and theirs was $80, i think.
does nismo make waterpumps for the rwd sr?
and does anyone know any good pistons i should get?
my pistons rings are fried. i need a piston ring set, but im thinking i should just buy a piston set, after all, tehy do come with rings.
anyone have any problems w/ the aftermarket pistons. knocking or anything?
