SR20DET Regrets?
Originally posted by ridesnowx4
does n e one know if the SR will pass emissions? I dont really know the emission laws here in AZ?
Originally posted by l2aine
that's a pretty good explanation
My stuff will be here soon though. I can't wait to drive this car.
The most fun I had driving a SR was in my AZ boy Blair's S14 with the same motor I got.
He needed suspension back then but the car was fast as ****.
Now I'm wondering, just how bad does an SR20DET not pass smog? I keep tossing ideas around in my brain...
- say an SR20DET tuned stock, with 2 cats and a super stockish muffler?
- or couldn't an ECU be setup to run the engine at specs that would pass smog (albeit with less power or hp)? For example, on my old SE-R I had the JWT ECU w+NOS module. What about reversing the roles on a DET-spec ECU? Instead of regular and NOS mode, technically isn't it possible to make one with turbo mode and "pass the stupid CA smog laws" mode?
- I know some people will bring up not even passing visual inspection, but that doesn't make sense if your car does pass the required minimum levels for smog - chrome air filter or not, you know what I mean?
- 2 downpipes, 2 ECUs. one would be DET ecu and normal turbo downpipe; the other, a downpipe that connects to the tuebo manifold (and a plate to cap the manifold since you'd TAKE THE ACTUAL TURBO OFF) with a stock, non-turbo ECU?
sorry.. still figuring out how to get a daily-driven DET in my engine bay.
i thought i heard something about turning the boost down really low, leaning out the fuel mixture, and making sure the motor is good and warm before testing?
Originally posted by -HyJynX-
hearsay, i wont believe it till i see it. And the visual test is the biggest one, isnt that the first test that they do? If they see a bright red engine in your car, I/C piping and a turbo....on a non turbo cars(if they know) then they SHOULD automatically fail you on the spot. Not give you a try at all. Is it really worth all that hassele raine? And btw...just go to a crooked smogger, it would be way easier.
#29
omg dude, where are u looking!? Unless prices have skyrocketed in the past 2 months, i had a hook up of 75-100 dollars to pass smog.
#30
try search. However, I heard before I bought my car (from AZ) that the smog laws in AZ were pretty close to CA... which means if that's true, then the SR passing smog? probably not...
