sr20det bluebird and sr20det gti-r
Old 10-05-2005 | 11:46 AM
tonyfizzle's Avatar
do sr20det bluebirds and sr20det gti-r's fit into s13? ive never even heard of the bluebird up untill recently. Whats the difference between these engines and a normal sr20det,ive heard of the gti-r being used in 200sx's ?('')
thanks
Old 10-05-2005 | 11:52 AM
nsn240's Avatar
Fwd engines
Old 10-05-2005 | 12:02 PM
tonyfizzle's Avatar
they are both fwd engines?
Old 10-05-2005 | 12:30 PM
nsn240's Avatar
yup they're fwd, the 200sx is fwd... cool link i just found:
http://sr20det.nismo.org/nissanengines.htm
Old 10-05-2005 | 01:00 PM
tonyfizzle's Avatar
good find
Old 10-05-2005 | 04:18 PM
StanBo's Avatar
Get a g20 or a sentra and drop your gtir in there. They are fun cars. I dd a g20. Seating for 4 and suspension rocks.
Old 10-07-2005 | 01:23 PM
GotSmoke?'s Avatar
doesn't the engine turn the same way, it is just turned sideways in the car? I believe it is the same engine but with a different tranny (and maybe ECU?)
I would very much want to find out if this is a viable option because all of the engine sourcers will sell you a bluebird front clip for the price of an s13 engine+tranny+harness+cpu
since I do not need the transmission for my project this would be ideal (if the cpu is the same)
Old 10-07-2005 | 01:24 PM
Waynehead05's Avatar
the engine is lateral
Old 10-07-2005 | 01:31 PM
GotSmoke?'s Avatar
An engine does not care how it is mounted. All that matters is the direction of rotation, the flywheel housing, etc.
I would suspect that the transmission and motor mounts are the biggest difference.
Old 10-07-2005 | 08:57 PM
CowboyTurbo's Avatar
ummm... NO NO NO!
yes it is possible to make it work, but to do so is going to bring the price up to the point where it's not worth it (unless you're DAMN good at custom fab). ANYTHING is possible with the right amt. of $$$
Old 10-08-2005 | 11:39 AM
codyace's Avatar
As stated above, the swap is possible, but very expensive.
Intake and exhaust manifolds, mounts, fans, valve cover, head....it's all different my friend.....
Don't be cheap with swaps or boost. A cheap swap will always cost more in the end
Old 10-10-2005 | 07:14 PM
StanBo's Avatar
The engineering, tools and skills needed to do it outweigh just getting a SR that mounts correctly.
Yes there are some goodies that can be shared from engine to engine with some modding but blocks...........
BILLYhoang
04-07-2010 08:04 PM
dr1fter
07-25-2006 12:13 AM
trevr
12-29-2005 10:59 AM
RyceRacerX
03-26-2003 10:11 PM
RNN14
02-08-2002 10:03 PM
