SR20DET = SR20DE + Turbo ?
Old 05-28-2003 | 05:13 PM
DRiFTiNgSiLViA's Avatar
Just out of curiousity. I have a 1993 Nissan 240SX 2-Door Coupe. Just got it and want to go the SR20DET route. If I go ahead and get the SR20DET off from Japan and plan on changing all of the internals for maximum boost capability + an aftermarket turbocharger, would it be the same thing as getting a USDM Nissan Sentra SR20DE and changing all of the internals, once again for maximum boost capability, and adding an aftermarket turbo charger.
Basically ...
Option 01 : Buy JDM SR20DET, rebuild motor, build internals, and replace turbo with aftermarket (not upgrade) turbo
Option 02 : But USDM SR20DE, rebuild motor, build internals (same parts as option 01), add aftermarket turbo (same turbo)
In the end, will these be identical engines or very similar? Or maybe not even close?
Old 05-28-2003 | 05:55 PM
Good question, never thought of it..but isnt the USDM sr20 FF?
Old 05-28-2003 | 06:47 PM
I'm with Stupid's Avatar
FF SR's WILL NOT fit.
Edit: I should say transversal SR's won't fit. So that includes AWD.
Old 05-28-2003 | 07:52 PM
Jeebs's Avatar
Yeah, America didnt get a RWD version of the SR i dont think. You could try to find an engine importer that would import the SR20DE out of the Silvia Q's. Thats the only thing i could think of.
Old 05-28-2003 | 08:03 PM
That's right. I forgot all about the different drivetrains. Stupid me. I remember people that were trying to throw the AWD bluebird engine into an FF altima and came across the same problem.
Old 05-28-2003 | 09:00 PM
Actually the Bluebird or Pulsar SR will drop in an Altima or Sentra/200sx/NX with a FWD SR's tranny. An AWD swap is possible too, but more complicated, I've seen an Altima converted to a Bluebird SSS Attessa on some Australian site.....
Old 05-28-2003 | 11:37 PM
BuudWeizErr's Avatar
Nope, not possible, sorry. A RWD SR20 tranny won't bolt up, the distributor will hit the firewall, and it just won't work in general.
The problem with getting an SR20DE is the fact that it will be as much, if not possibly more than an SR20DET for the simple fact that the DET is more popular.
Old 05-29-2003 | 06:38 AM
that was the other problem
I know which one you're talking about. There was one guy on the altimas.net forums that did the conversion too. He was greatly criticized because after all of the money that he put into somehow making his altima 4WD, all he has now is a stock car. for ALL that money. IMO, i think it's worth it because a big change such as FF to 4WD can make your car a lot better of a base to use for modding (plus it's an SSS) heheh. Yea, I was thinking about doing that to my Altima, but I love my 240 way better. RWD beats FWD any day in my opinion. But that's only because I love to drift. RWD drifting is a LOT more fun. hehhe, IMO.
Old 05-29-2003 | 06:56 AM
Justin.b's Avatar
Just curious why you would go through the trouble of rebuilding the SR. Are you planning on going over 400hp straight out of the box? If not, that sounds like a major waste of money and time to dis-assemble a running low-mileage motor.
-Justin
Old 05-29-2003 | 04:34 PM
-Justin
Simple answer : YES!
Old 05-29-2003 | 04:46 PM
Justin.b's Avatar
Well then why are you here looking for a nickel and dime solution for a starting point. Order an SR20DET. You need the transmission anyway.
With those planned power levels you are definitely better off starting out with an RB25.
-Justin
S15
03-19-2004 11:32 AM
S15
01-13-2004 11:17 PM
irax
12-09-2003 10:40 PM
bonomo
11-22-2003 06:58 PM
positron
02-17-2003 12:02 PM
