SR20DE vs SR20DET
Old 04-06-2004 | 06:26 PM
craigkiel's Avatar
SR20DE vs SR20DET
Other than the turbo, are there any differences between the two? Thanks,
-Craig-
Old 04-06-2004 | 06:30 PM
craigkiel's Avatar
Also is it any cheaper getting the DE aand turboing it rather than the DET?? Thanks,
-Craig-
Old 04-06-2004 | 07:11 PM
craigkiel's Avatar
forgot to mention that im meaning JDM engines not the FWD USDM
Old 04-06-2004 | 07:20 PM
T707S13's Avatar
ya, lots of loss of HP!!!!!. . .J/K ( i guess that has to do with having a turbo huh? ) lol.
Tom
Old 04-06-2004 | 07:25 PM
craigkiel's Avatar
lol.... yeah
Old 04-06-2004 | 08:22 PM
Not 100% sure but Im just going by memory
The head is different, obvisouly the power, internals...maybe more. Its better to just get the SR20DET, not the DE.
Old 04-06-2004 | 08:40 PM
craigkiel's Avatar
I read some where that the internals are the same. But I will take your word Jynx! Thanks,
-Craig-
Old 04-06-2004 | 08:43 PM
MoxMonkey's Avatar
t=turbo enough said
Old 04-07-2004 | 07:24 AM
4DoorSR's Avatar
Compression among a few others.
Old 04-08-2004 | 07:37 PM
Gary43's Avatar
i just finished building an DET and a DE. just about everything is different. i used the pistons out of the DE but when i went to turn the engine to make sure it turned over smooth the pistons hit the oil squirters. i found out the DET pistons have notches cut out for the oil squirters. i just modified the oil squirters and so far it looks like it will work.the DET also has bigger rods and lower compression. i think the crankshaft is the same also.
Old 04-16-2004 | 12:47 PM
lionel's Avatar
i used to own a DE, and i can tell you from experience the engine is good enough for drifting. as far as turbo'n it, that's not very bright. just get a DET.
craigkiel
04-08-2004 07:30 PM
irax
12-09-2003 10:40 PM
bonomo
11-22-2003 06:58 PM
DRiFTiNgSiLViA
05-29-2003 04:46 PM
positron
02-17-2003 12:02 PM
