SR20 wiring diagram and US parts matching
came across this... http://www.eurostreetgraphics.com/srwiringdia.htm
it shows the SR20det wiring diagram, s13 ecu pinout, and US parts that fit on the SR
hope someone finds it useful
in case you cant access it for some reason...sorry the pics wont post
SR20DET Wiring Diagram
This is a copy of the Repair manual for the SR20DET S-13, Thanks to a Friend "Jack" of mine that lives in Japan.
Its in Japanese but can still be deciphered .
If you need a clearer picture of the Diagram E-Mail me. This is good to have for trouble shooting.
Advertise here if your shop carries OEM and performance parts for the SR20DET engine.
(CLICK HERE) for e-mail
SR20DET ECU S-13 PINOUT
ECU PINS Description of use Wire color
1 Coil Pack 1 Output (Via power transistor Unit) Red White
2 Coil Pack 2 Output (Via power transistor Unit) Red Yellow
3 Tachometer signal output Yellow Red
4 ECCS Relay Red Black
5 Ignition Pulse Monitor (For Trip Comp ?)
6 Ignition Signal Ground Black
7 RX data (Signal from Nissan Consult hand terminal) Green Black
8 Coil Pack 3 Output (Via power transistor Unit) Red White
9 Coil Pack 4 Output (Via power transistor Unit) Red White
10 -
11 -
12 A/T signal DT3 (autotrans gear select ?)
13 Ignition Signal Ground Black
14 CLK clock (timing signal) Green White
15 TX data (signal to Nissan Consult hand terminal) Green
16 MAFS signal input ( Mass Air Flow Sensor ) White
17 MAFS ground Black
18 Water Temp Sensor input Blue Brown
19 Oxyen Sensor input (O2) White
20 TPS input (throttle postion sensor) White
21 Sensor ground Black
22 CAS 180deg signal (Crank angle sensor) White
23 CHK check (check start) ? Green Red
24 Monitor check Lamp (red) (fault code lamp output)
25 Exhaust over temp warning lamp output Orange
26 Exhaust temp sensor inout (Behind the Cat) Blue Yellow
27 Detonation sensorinput (knock sensor) White
28 TPS for A/T (kick down switch)
29 Sensor ground Black
30 CAS 180deg signal (crank angle sensor) White
31 CAS 1deg signal (crank angle sensor) Black
32 Speed sensor input Yellow Green
33 -
34 Start signal (from ignition switch) Orange
35 A/T neutral switch input Green Orange
36 IGN (ignition ON, from ignition switch) Black Red
37 TPS power output (power to throttle position sensor) Light Green Red
38 ECCS power Black White
39 ECCS ground Black
40 CAS 1 deg signal (crank angle sensor) Red Black
41 A/C on input (Air Con ON from A/C panel) Blue Green
42 A/T signal DT1 (auto trans gear select ?)
43 Power steering switch (speed proportional control output) Purple White
44 A/T signal DT1 (auto trans gear select ?)
45 Ambient air tamp sensor input Blue White
46 ECCS backup power Red
47 ECCS power Black White
48 ECCS ground Black
101 Injector No. 1 drive output White Black
102 EAI control solenoid output (egr valve control ?) Orange Black
103 Injector No.3 drive output Green Black
104 Fuel pump relay output Black Purple
105 Fuel pressure control module Red White
106 A/C on output (Air conditioner on relay signal) Green Black
107 Injector ground Black
108 Injector ground Black
109 Reverse electrical flow return circuit (alternator fail input) Red
110 Injector No. 2 drive output Yellow Black
111 Turbo boost pressure control solenoid (over boost cut ?) Orange Black
112 Injector No. 4 drive output Blue Black
113 AAC valve control (Auxiliary Air Control, Idle speed control) Light Blue
114 -
115 -
116 Injector ground Black
I'ld like to thank Martin in Australia for allowing me to use this info on my page
SR20DET PARTS LIST
This section is dedicated to replacement parts.
NISSAN SILVIA (PS13)
ENGINE OVERHAUL GASKET KIT & PART NUMBERS
These are Japanese Part Numbers, Not to be used at U.S. Nissan Dealers.
PART NAME PART CODE KIT # 11011K KIT # 11042K
Gasket Kit: Engine repair 9101-11011K 1 -
Gasket Kit: Valve Re-grind 9101-11042K - 1
Seal: Oil Crankshaft Rear 9101-12279 - 1
Gasket: Drain Plug 9101-11128A 1 -
Gasket: Cylinder Head 9101-11044 1 1
Gasket: Chain Tensioner 9101-13070E 1 -
Seal: Oil Valve (intake) 9101-13207 8 8
Seal: Oil Valve (exhaust) 9101-13207M 8 8
Gasket: Rocker Cover 9101-13270 1 1
Gasket: Rocker Cover 9101-13270M 1 1
Gasket: Rocker Cover 9101-13270N 4 4
Gasket: Oil Filler Cap 9101-15255A 1 -
Seal: Oil Crankshaft Font 9101-13042 1 -
Seal: O-rings 9101-13035H 1 -
Gasket: Intake Manifold 9101-14035 1 1
Gasket: Collector, Intake 9101-14010A 1 -
Gasket: Throttle Chamber 9101-16293 1 -
Gasket: Exhaust Manifold 9101-14036M 1 1
Seal O-ring Oil Strainer 9101-15053M 1 -
Seal: O-ring Pressure Regulator 9101-16412E 1 -
Seal: O-ring Injector, Lower 9101-16412F 4 -
Seal: O-ring Injector, Upper 9101-16412G 4 -
Seal: O-ring Support, Distributor 9101-22100E 1 1
Gasket: AAC Valve 9101-23785N 1 -
Gasket: Turbo Charger, Inlet 9101-14415 1 -
Gasket: Turbo Charger Outlet 9101-14445 1 -
Gasket: Inlet Tube, Air 9101-14465M 1 -
Gasket: Oil Tube, Inlet 9101-15196 2 -
Gasket: Oil Tube, Outlet 9101-15196M 1 -
Gasket: Connector, Water 9101-15188A 6 -
Gasket: Liquid 9101- 1 -
These part numbers are also curtesy of Jack in Japan.
MORE PART NUMBERS
Part Description Part Number
Mass Air Flow Sensor 22680-52F00
Ignitor Chip 22020-50F01
Clutch Disc 30100-96E08
Clutch Plate 30210-6E602
Nismo Clutch Disc 30100-RN580
This Mafs part number is thanks to Edwin from New Jersey.And thanks to Marco from Cali. for the Clutch numbers.
PARTS IN THE U.S. THAT FIT THE SR20DET
PART DESCRIPTION CAR YEAR CAR MODEL
STOCK NISSAN CLUTCH 89 MAXIMA W/ TIMING CHAIN
IGNITOR CHIP 96 INFINITI Q-45
THROTTLE BODY 91-98 240SX DOHC
OIL FILTER 92-99 SENTRA/200SX SE-R
SPARK PLUGS 92-99 SENTRA/200SX SE-R
MAFS (will need plug) 89-90 240sx 12 valve
10 -
11 -
33 -
114 -
115 -
SR20DET PARTS LIST
MORE PART NUMBERS
