sr20 installed but wont start? need help
Old 05-10-2006 | 09:04 AM
ZKaosKid's Avatar
we installed the sr20det and everything is hooked up, we have the sr20 wiring harness in. we did not change the fuse box or any other wires? is it needed. cause the car we pulled the motor out of had an extra fuse that mine didnt. i had the reading on my fuse box top. but just an empty spot? would that matter. everything else seems hooked up. we get power and when i try and turn it over i hear a clicking. we think its a wiring problem but we cant figure it out.
Old 05-10-2006 | 10:43 AM
make sure all your ignition is good as well, just throw somefuses in those empty spots, it couldnt hurt
Old 05-10-2006 | 01:10 PM
ZKaosKid's Avatar
got it. there was a connector that didnt have a place to go so we randomly stuck it on the started ground and it worked. but thanks now i have a drivable sr20det
Old 05-10-2006 | 01:57 PM
ka-tfresh's Avatar
con grat you la shuns
i don't know.....
Old 05-11-2006 | 01:01 PM
zamurai's Avatar
How long did it take you to install the motor? and where did you order it from?
Old 05-20-2006 | 08:12 PM
it probably your battery, usually when youve got a dead battery you hear a clicking noise when your trying to start it.
Old 05-30-2006 | 09:39 PM
kevtrinh's Avatar
what did the connector look like?
Alexl08
07-19-2007 04:53 PM
boooosted
05-10-2007 08:05 AM
spoolin240
09-24-2006 10:01 PM
nschultz0124
08-15-2005 06:47 AM
KA240
05-31-2005 04:30 AM
