sohc AC compressor bracket on redtop SR20det
Does anyone know how I could make a bracket so that I could use my s13 sohc AC compressor on my redtop sr20det?
From searching, I've heard that you can make a simple bracket but nobody specifies on how to make one and out of what material.
The reason why I want to use the sohc AC compressor is because I dont want to cut and modify the lines to the Sr20 AC compressor lines and also recharge the AC. All i really need to do is find a way to bolt the sohc compressor on the sr20.
If no one here knows, www.xatracing.com are the people that did my swap and they made mine work so maybe they could help u out..
90 Sileightyguy
05-14-2008 10:02 AM
Halcyon
03-16-2007 05:24 PM
yektik99
12-29-2004 04:49 PM
