S13 swap
Old 11-09-2002 | 11:05 AM
Heely's Avatar
also i have been checking the links for SR20's and some places say they have 205HP and others say 250. what is the correct amount of HP?
Old 11-09-2002 | 12:13 PM
rudeboy's Avatar
you can drop an SR into a gang of diffrent nissans.
but as far as 240's go take your pick.
there are more pain in the *** procedures for the 89-90 but it'll go in anyway.
Old 11-09-2002 | 04:29 PM
boro240's Avatar
you dont need to swap out the entire guage cluster. you can just change the tach and it works fine. i forgot the web site where they give instructions and pictures.
Old 11-10-2002 | 02:34 AM
spitz7985's Avatar
both are correct. the s13 motors are 205 and the s15 motors are 250.
Old 11-10-2002 | 04:00 PM
altima/240sx's Avatar
so an s13 SR20det can be an easy install into a USspec S13 correct? I always here that an S13 will be a pain to do, but if you just use a S13 SR, it shouldn't be too difficult to have it fit.
Old 11-10-2002 | 09:58 PM
rudeboy's Avatar
remember the motor is standard(de/det) in japan. the motor will bolt in just like a KA. wiring and hoses are the olny real difficulties.
depending on year
Old 11-12-2002 | 01:19 PM
Heely's Avatar
so let me see if i understand...
- it is easier to do a sr20 swap into a non 89-90 s13
- s13 sr20 has 205HP
- s15 sr20 has 250HP
can a s15 sr20 go into a s13 240 just as easily?
Old 11-12-2002 | 04:32 PM
tantrumS13's Avatar
Yup, only wiring the damn thing will be a biatch. I have a S14 in a 90 coupe. I heard wires had to be found in the dashboard somewhere and extended out to the engine compartment, etc.... I heard it was a bit of a nghtmare, since i wanted them to use the full S14 harness and ECU. But my car runs fine though, the tach is dead, so boro240 if you could send me that link, i would appreciate it. My speedo is reading all wrong, it maxes out at 36 MPH when I know i am going over 100MPH. So minor crap here and there
Old 11-12-2002 | 09:43 PM
spitz7985's Avatar
no. you need custom **** like motor mounts. it's not easy. not worth the extra cash, IMO. the s13 is capable of just as much and you can save money by going with it. that way you'll have an extra grand and a half or so to dump into the engine right away. most do not recommend the s15.
but it duz have a 6-speed, which would be tight.
Old 11-12-2002 | 10:52 PM
boro240's Avatar
heres the link to wire the tach:
http://sr20.hybrids.jp/installations...ter/index.html
Old 11-13-2002 | 10:05 AM
  #26
tantrumS13's Avatar
boro240, thanks for the link, but do you know if it makes a difference if I have the digital speedometer with the heads up display? I wanna retain that since mine still works. Do you think it would be better if I just swapped in the JDM cluster with the HUD? At least that way i can get an accurate speed reading in Km/H.
Thanks
Old 11-13-2002 | 12:16 PM
  #27
I'm with Stupid's Avatar
uhhhh.....S15's drop in. The only problems with them is that the speed sensor is mounted on the diff rather than the tranny, so you need the drivetrain for an install. Other than that you just have to deal with OBDII wiring, which a shop can do for you.
Old 11-13-2002 | 06:49 PM
  #28
boro240's Avatar
Thanks
the only thing that should have a problem is the tach, so no need to swap the entire thing out. often times more problems can arise if you do. i saw one guy who messed up his fuel guage so it was extreme negative. also im sure it easyer to just do the tach than the whole cluster. (also tampering with your odometer is illegal, but i supose thats not too big a deal if youre already gonna use an illegal motor )
Old 11-13-2002 | 08:24 PM
  #29
91240sx's Avatar
hey whats up if your wanting to do the swap i suggest , but its only a suggestion ....get the front clip it will save u alot of hassle of tryin to find all the parts u need to do the install. but as the others was sayin 91+ is the easiest route to go. im doin the swap as we speak
Old 11-15-2002 | 02:17 PM
  #30
does the driveshaft of the s13 KA and SR mount up together, or do i need a new driveshaft too?
