Redtop Swap In S14 (ka A/c Compressor On Sr20?)))
i know this works.......somehow..... the a/c wiring seems to be standalone away from the engine wiring harness on an s14..
it is a 95 s14......(obdI)
did an s13 redtop sr20det swap....
i have the compressor mounted.
i can see that the use of a 3 rib belt will be needed and offset one rib since it doesn't line up correctly.
question i have is when it's charged.....will the wiring work?
if not, what the prob?
need a constant 12v with a relay or what?
thanks in advance to the guru who knows this......
SlmdCpe
01-10-2014 01:31 PM
yektik99
12-29-2004 04:49 PM
totalled 96 se
02-29-2004 01:16 PM
