rb26 in 89 coupe
rb26 in 89 coupe
besides the mounts, cross member, radiator, wiring, what else am i looking at needing. And has anyone done the swap that can give me some advice.. i have the motor already going to mod it before it goes in... so any advice or hints would really be appreciated
are you taking off the twin turbos and using one big one? if you do there will be a lot more room to work with. A new speed sensor would help. cause my rb25 doesn't display the right speed when i am driving. also i would use the rb25 transmission because it is rear wheel drive and not all wheel drive.
Fans, timing belt, tensioner pulley, idler pulley, water pump, depending on motor you may need to mod the crankshaft to avoid oil pump failure, thermostat, clutch, RB25 oil pan, RB25 transmission, driveshaft, drive belts, You will need to mod the block for the different oil pan, new filters, exhaust, There is probably more, but I am brain dead right now.
yes im taking of the twins.. bought a maniford and turbo offline that fits perfect. why do i have to change the pulleys and mod the block for a oil pan.. why wont the factory one's that came with the motor work? i appreciate all of your guys imput
Pulleys for safety & convenience, you dont want to spend all that time changing the timing belt, then have the pulleys be bad and do it again once the motor is installed.
The block is setup for the dipstick to be in the wrong spot for the front sump RB25 oilpan, you gotta swap it around & seal up the old hole.
miatex
11-20-2003 08:57 AM
