rb25det wiring and other infor
Old 12-05-2003, 05:22 PM
JPierce's Avatar
thats good to hear, maby i will give u a lil help getting back in the game when i get ready to do my harness and give you some business....good luck, hope everything goes well
JPierce is offline
Old 12-05-2003, 09:16 PM
NightXCZ77's Avatar
Like I said man, I would refer a lot of people to you if you want to do the wiring stuff....and learn the RB20 as well...Hope everything works out well, can't wait for the come back =o)
Night
NightXCZ77 is offline
Old 12-08-2003, 07:38 AM
jonpowell's Avatar
Cameron, I am working on it now,
S13, S14 SR20DET into S13 and S14
RB20DET, RB25DET, and RB26DETT into S13 and S14.
Will be ready in about 2 weeks.
Thanks!
jonpowell is offline
Old 12-08-2003, 06:11 PM
JPierce's Avatar
aight guys keep me informed, also, what type of tools will i need to do the swap.....i have the basics but im sure there will be some things that i will need, can you give me a rough tool list please.
JPierce is offline
Old 12-08-2003, 10:16 PM
NightXCZ77's Avatar
Thanks!
I've got tears in my eyes such a beautiful thing Can't wait Jon....can't wait!!! I'll help you out as much as I can with that...even on my own installs, it would save me some time lol.
Night
Old 12-09-2003, 06:06 AM
jonpowell's Avatar
Ratchets, Sockets, 8MM, 10MM, 11MM, 12MM, 13MM, 15MM, 17MM, 19MM and a big *** one for the crank pulley bolt, I cant remember the size. I good pulley puller. Miscelaneous screwdrivers, hammers, and hole saws. And a good supply of patience.
Old 12-09-2003, 06:22 PM
JPierce's Avatar
thx, the standard torque wrench also i suppose
JPierce is offline
Old 12-10-2003, 04:45 AM
jonpowell's Avatar
Yeah, I forgot about that one.....I am sure there are more but I can't remember too much now.
Old 12-10-2003, 05:28 PM
JPierce's Avatar
john, what did u use to get the engine in in your install, did you
A: Hoist the engine and tranny together and slip them in at an angle with the car on jack stands or something.
B: Hoist the engine and put it in place then put the tranny up from underneath. while the car is on jack stands and what not of course.
or C: Raise the car some how and lower the car on the engine and what not.
or one of the other possabilities. I need an easy way to do it w/o a lift, dont have one or access to one, can rent or possibly borrow a hoist.
Thx
JPierce is offline
Old 12-11-2003, 04:53 AM
jonpowell's Avatar
I think the easiest way is to raise the motor in. I dropped the motor and then lifted the trans. The only problem is getting it all to clear the trans tunnel.
If I was to do it again, I would assemble them on the ground and install them from below as a unit. I think it would be much easier.
The other way(the third time I installed the motor) I had the head off. Loosen up the motor mounts and the motor will rotate back into the trans tunnel and you can connect the transmission that way with easy access to all the bolts. I think the easist is to raise the assembly into the engine bay.
Thanks!
Old 12-11-2003, 09:11 PM
  #26
JPierce's Avatar
alright, but now i need to devise a plan to do that, i dont have a lift or anything and i dont think that jack stands will be high enough to get the motor under it.
maby i can use a engine hoise and raise the front of the car or something, think it will take the weight? who knows, i might just have to do it the hard way.
any ideas?
JPierce is offline
boosted-alty
02-15-2007 12:08 PM
my s14
06-25-2006 10:49 PM
s14 rb25det
08-29-2004 07:34 AM
240SEX
11-02-2002 12:04 AM
ChibaDrifter
05-23-2002 04:23 PM
Quick Reply: rb25det wiring and other infor
