RB20 Swap Guide Help!!!
Old 07-14-2007 | 10:32 AM
MATTs14's Avatar
I was wondering if anybody knew where i could find a good writeup on the rb20 swap. if not could somebody just post what all would be needed to do the swap. thanks MATT
Old 07-14-2007 | 10:57 AM
Durdan's Avatar
what write up?
take the KA out
put the RB in using a mount kit
send the harness out to get rewired.
thats it.
Old 07-14-2007 | 11:23 PM
MATTs14's Avatar
well i know that lol. and im using all stock mounts
Old 07-14-2007 | 11:35 PM
thatloserkidqui's Avatar
yank the ka cross member out and bolt the rb cross member in. It's really not that hard. Lower the rb in and bolt the rb mounts to the cross member with the tranny attached. Bolt the tranny cross member in and stab the driveshaft. Connect all the wires on the rewired harness. Connect all the vaccum lines. Fill all the fluids and prep the motor to start.
It's really an easy swap
Old 07-14-2007 | 11:47 PM
Stock KA mounts? They won't line up man, the RB mounts are different.
Old 07-15-2007 | 03:25 AM
yarou's Avatar
you'll need an r32 subframe if i remember correctly (i might be wrong, this swap is on my never do list)
Old 07-15-2007 | 03:28 AM
Just the engine crossmember and the rb mounts...Iunno if the KA mounts work I used the rb ones
Old 07-16-2007 | 01:11 AM
MATTs14's Avatar
well thats what i meant lol. any good tips for when doing the swap?
Old 07-16-2007 | 01:13 AM
Get all the stupid crap done before you put the motor in. Get the sensors off the ka tranny and put them on the rb tranny before you put it in. The crossmember is a slight ***** to get out so just be patient with it. Just try to get as much done as you can with the engine out of the car
Old 07-18-2007 | 01:58 PM
HKST04Z's Avatar
this is what i have done.
rb20det front clip
top hat motormounts
mckinney motorsports single piece driveshaft
3" downpipe
modified throttle cable bracket
dual pusher fans
Fmic
hcr32 fuel filter
Old 07-18-2007 | 03:09 PM
MATTs14's Avatar
how do you do the throttle cable bracket? any pics or tips?
Old 07-18-2007 | 03:34 PM
HKST04Z's Avatar
id have to take pics for you when i get the chance, but all you do is extend the stock bracket or just make a custom one that will move the cable closer to the throttle body
Old 07-18-2007 | 04:49 PM
Yea I just took a piece of basically that metal strip that they use to hang ducting and cut a short piece of it. Bent it into an L shape and notched out the side. Bolted it where the old bracket was and called it a day. Works great ill take pictures eventually
Old 07-28-2007 | 11:03 AM
S13coupeRBpower's Avatar
thread starter..installing the engine is very very easy.
yes change the crossmeber.. this what i did...
i bolted my r32 crossmember to my rb20.
i yanked out all my ka crap..
i had my car high up in the air on jackstands..
then i placed my rb20det engine/bolted on the crossmember already.. i sat the engine on a dolley and i rolled the engine under the car...
then i used my engine hoist to pull it up in the bay.. and bam it was sooo easy to line it up... and bolted in the crossmeber to the chassie..
easy!!! took less than 20 mins to put the engine in.
and edit.. ka mounts dont' work.. they suck anyways why re-use them. lol
Old 07-29-2007 | 01:20 AM
Talde's Avatar
wat about wire wise. can some say anything detailed about it. all ive read was. ship it out to get converted. wat is being converted? im a diy kinda guy. i like to know so i can teach my friends. thanks
