Ran my car at the strip
Old 08-12-2004 | 09:25 PM
chrs13's Avatar
Well I went to the local drag strip the other night and it turned out to be a good night. Here is the list of my mods.
93 240sx coupe
SR20DET Blacktop
Intake
3" Blitz Downpipe
3" Test pipe
3" Catback
HKS FMIC
Greddy Type S BOV
Greddy/Trust Oil pan
HKS Turbo that came on the motor, so I don't know which kind it is
Greddy Profec B boost controller
Greddy Hot pipe
S15 stock LSD
ACT XTSS Clutch
and Yokohoma AVS ES100's on the rears at 20psi
I was running 12lbs of boost and my speed governor is still in which is causing me to hit it about 40 feet before the end of the strip.
Anyways here is what I ran, and I have such a low trap because of the speed governor hitting and making me coast the rest of the way.
R/T: .775
60': 2.036
330: 5.729
1/8: 8.690
MPH: 84.55
1000: 11.236
1/4: 13.431
MPH: 96.46
I was pretty happy with that. Especially the fact I was hitting my speed governor 40ft before the end of the track which sucked. Anyways, taking a rough guess I'm saying I could easily pull a 13.2 and if I can pull another 1.9 60' like I've done before, possibly even a 13.1 . Who knows, let me know what you all think?? Comments, suggestions welcome.
Old 08-12-2004 | 10:14 PM
Running a torsen LSD huh? Nice.
Pretty nice times, just need to get rid of that s.g. Your hitting the s.g. in 4th?
Old 08-13-2004 | 06:45 AM
jonpowell's Avatar
cut the wire that fees the speed signal to the ECU and your SG will be gone!!!
Old 08-13-2004 | 02:10 PM
chrs13's Avatar
If I knew which wire was for the speed governor, I'd love to do that. I just don't want to mess something up and cut the wrong wire.
Old 08-13-2004 | 04:07 PM
jonpowell's Avatar
look for the SR20DET inpouts and you will be able to figure it out....
I will look into it also for you
Old 08-13-2004 | 04:11 PM
jonpowell's Avatar
Pin 32
Old 08-13-2004 | 09:45 PM
chrs13's Avatar
Thanks I'll see if I can figure it out.
Old 08-14-2004 | 10:55 PM
lanb135's Avatar
dont you also have to pull the tranny sensors for 4th and 5th gear?
Old 08-15-2004 | 07:51 AM
jonpowell's Avatar
No, just cut the speed signal to the ECU and it has no clue how fast you are going. This is what I do with the Rb25 installs I do so that there is no speed governer. The SR20 is very very similar in alot of ways.
Old 08-15-2004 | 09:29 AM
xjon's Avatar
Jon- I tried to do that with my ka and it used to the check engine light on. I reconnected it back because I wasn't sure if it would make it go into safe mode. But if you always do it, and not have any problems with it, then looks like it's all good.
Old 08-15-2004 | 10:08 AM
Jedi Mind Gamez's Avatar
is it the same with the rb20??? Will my speedometer still work? and What pin is it??? 32?
Old 08-15-2004 | 11:37 PM
240hooker's Avatar
The signal goes from the Transmission to the instrument cluster and then to the ECU. I raced a SLK 550 on the interstate and not only did I wip his ***, I also hit 150 mph. My SR impressed the hell out of me that day.
Old 08-17-2004 | 03:13 PM
Brad's Avatar
Those are sick times man! Do you have any idea what kind of power you are putting to the rear wheels? Ballpark, or dyno?
flyboy367
06-01-2008 07:55 PM
Runya
01-08-2007 12:11 PM
240sxDriver
11-13-2006 04:34 PM
chrs13
07-18-2004 08:32 PM
drftordie
01-23-2004 12:02 PM
