Oil leaking from valve cover breather??
Old 12-09-2005 | 02:24 PM
robalicious96's Avatar
I noticed latley that some oil has been leaking out through the valve cover breather. a friend of mine says it could be a sign of bad piston rings. anyone else know anything about this symptom??
Old 12-09-2005 | 02:27 PM
PNG's Avatar
PNG
Is it an open element breather, or the stock PCV connection?
Old 12-09-2005 | 05:04 PM
i believe it is the stock connection
Old 12-09-2005 | 05:22 PM
PNG's Avatar
PNG
Check/replace your PCV valve and inspect the hose(s) to make sure they aren't plugged. Normally, when the engine's running, the intake draws a constant partial vacuum on the valve cover to relieve pressure from (normal) blow-by. If the PCV system is compromised, pressure will build up in the crankcase, even if you have a good ring seal.
Old 12-09-2005 | 09:05 PM
nsn240's Avatar
put a catch can back on it
240SX turbo
11-08-2006 06:29 AM
91240SXGuy
04-01-2006 08:56 PM
peterm
08-16-2005 05:04 PM
izzen
02-04-2004 01:27 PM
izzen
02-03-2004 03:49 PM
